98ci compression?
Old Aug 8, 2025 | 06:59 PM
OnlyHarley's Avatar
OnlyHarley
Stage III
Default 98ci compression?
I have a 2006 Heritage Softail that is bored to a 98ci from an 88ci. Im running S&S 509 cams with stock heads and I'm getting cold compression test readings at 210 on both cylinders. What can I do to get my compression down to 180 or 190. Would head work be the way to go? What's your alls opinion on this? Any suggestions?
Old Aug 8, 2025 | 07:03 PM
Silentgreyfellow's Avatar
Silentgreyfellow
Why do you want less compression?
Old Aug 8, 2025 | 08:06 PM
OnlyHarley's Avatar
OnlyHarley
Stage III
[QUOTE=Silentgreyfellow;22088020]Why do you want less compression?[/QUOTE
I was told my compression is way to high, especially for pump gas. The bike runs great, ive had it dyno tuned and no issues with it. When i was told that 210psi was too much it had my mind racing and just wanted some different input from people.
Old Aug 8, 2025 | 08:25 PM
hattitude's Avatar
hattitude
At 210psi, you are most certainly in an area where detonation can happen without a great tune and possibly also running expensive, high octane fuel (race gas).
If it was tuned at that compression on pump gas, and it runs well, I see no reason to change the compression..... unless....
How easy is it to start? That compression can also wear down a starter. You'll need to have a high CCA battery, keep it in good condition, along with good, clean battery cables.
But even if there were starting issues, to save wear & tear on the starter, I would add compression releases before reducing the engine compression on a well made, well tuned, and great running engine...
Good luck and keep us posted on what you decide to do...
Max Headflow's Avatar
Max Headflow
[QUOTE=OnlyHarley;22088065]
If it's running great, you found someone that knows how to tune the bike.. Ignore the guy that fed you the BS..
Old Aug 9, 2025 | 08:27 AM
OnlyHarley's Avatar
OnlyHarley
Stage III
it starts without any hesitation. I run a Vulvan compensator eliminator and a Noco Lithium battery with 700cca. Other than running a little rich, my dyno tune was done at BigBarn Harley-Davidson. Idk, maybe It wouldn't hurt to run some octane booster in the old girl. She's quick, but I don't hot rod her. (too often)
Thanks for your input guys. And compression releases are in the winter plan book, with some slight head work and a thicker head gasket. I think its a rock solid bike, that guy just got in my head a little.
Will post later..ride safe brothers
Old Aug 9, 2025 | 12:09 PM
djl's Avatar
djl
Agree with the previous posters. I run a 98" motor with CCP at 212psi; static is 11.75 but it was tuned by someone that knew what they were doing and I do run manual compression releases and a high CCA lithium battery which help on heat soaked hot starts. I do run premium fuel, it was 102* in south Texas yesterday and won't start cooling off until September; no detonation. If the motor does not ping, no need for octane booster. a waste of money.
Old Aug 9, 2025 | 06:13 PM
Rains2much's Avatar
Rains2much
230 on the street in Florida heat with a shovelhead using pump 93 octang gas…. You’re fine. 93” 1970 Andrew’s M grind, DynaS, single plug heads 28 degrees timing G carb, Drag pipes.
InthewindMN
Engine Mechanical Topics
13
Nov 10, 2016 10:55 AM
txphatboy
Exhaust System Topics
Mar 4, 2013 02:28 PM
Hammy
Feb 22, 2011 08:39 AM
UltraKla$$ic
Sep 24, 2009 11:08 AM
George C
Feb 3, 2006 11:08 AM
