2012 Fat Boy wiring
Old Aug 28, 2025 | 10:17 AM
funky monkey 69's Avatar
funky monkey 69
Stage I
Default 2012 Fat Boy wiring
Hi,
i have a 2012 Fatboy, that is a U.K. spec bike however, i want to have the front turn signals operate in the same way the U.S. spec bikes work, meaning i can run a white running light, with an amber turn signal.
I was wondering if anyone on here knows what parts i would need for this? I'm assuming it's just a wiring difference?
I've asked a couple of my local dealers but, they're of little help as they have both said the same... "we don't know, we've never worked on a U.S. bike".
I'm really hoping someone on here may know the answer. The closest I've got to an answer is, that the wiring loom is the same on U.K. & U.S. bikes, right up to the turn signals, at which point the U.S. bikes have three wires to the turn signal housing & the U.K. bikes, only two. Does anyone know the differences &/or how to do this, what parts i need etc...
Any help on this would be much appreciated.
Thanks.
Old Aug 28, 2025 | 11:26 AM
eighteight's Avatar
eighteight
Exploded view of parts with numbers and wiring harnesses can be viewed at Ronnies Parts finder
Schematics also available by entering your VIN into Harley Service Portal
Get a comfy chair and a large screen, you might be there awhile
Old Aug 28, 2025 | 12:14 PM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The US domestic bikes I think you will find have an amber lens with a dual filament bulb. The running light therefore will be 5Watt amber and the indicator will be 21Watt amber.
Your HDI bike has a single filament bulb so you would need the domestic market bulb holder that has 3 wires.
Another solution that will give you a white running light and an amber indicator is to fit the Custom Dynamics ringz turn signal. It has the extra wire that will go to the indicator connector, possibly under the tank but don't know your bike.
Wiring diagram here:- 99949-12_en - 2012 Wiring Diagrams
Custom Dynamics ProBEAM ECE Approved Amber/White Dynamic Ringz With Smoked Lenses For Harley Davidson Motorcycles (PB-AW-ECE-1156) | ARH Custom UK
I have fitted the CD ringz to my bike and put the extra wire in heatshrink along with the existing wires for a neat installation. The connector under the tank is a 6 way with the running light pins empty. I bought the pins to do a proper job so I can remove the ringz if necessary.
Old Aug 29, 2025 | 12:39 AM
Roberto88's Avatar
Roberto88
You'll need to replace the two-wire turn signals with three-wire US-spec ones. The wiring harness should have the third wire tucked away; you'll need to connect it for the running light function.
Old Aug 29, 2025 | 03:55 AM
Andy from Sandy
The connector for the front indicators is under the tank. The connector, 31, is a 6 place 070 multilock type. The connectors and pins are readily available from other places apart from HD.
AMP/Tyco Multilock terminals
Pins are flat and 1.8mm wide
HD part number Amp/Tyco part number
73190-96 Pin 173645-1
73191-96 Socket 173631-1
Multilock connector housings
73106-96BK Pin housing 6-way 174930-2 Receptacle
73156-96BK Socket housing 6-way 174923-2 Plug
HunterBLT
May 20, 2023 07:50 PM
B.K.
Electrical/Lighting/Alarm
Jul 29, 2022 08:03 PM
Donny502
Jan 31, 2022 08:51 AM
14FatBoyLo
Aug 27, 2020 11:23 AM
1badaxe
Jan 9, 2008 03:25 PM
