bike weight
Old Sep 4, 2025 | 06:34 AM
Boat Bum's Avatar
Boat Bum
Double up on leg day.
Old Sep 4, 2025 | 06:47 AM
Bone Doc's Avatar
Bone Doc
I don't have any advice. I'm just impressed that @heybaylor is still riding at 84 years old. More power to you .
Old Sep 4, 2025 | 06:50 AM
Boat Bum's Avatar
Boat Bum
^ For sure.
Old Sep 4, 2025 | 08:00 AM
Rains2much's Avatar
Rains2much
I wouldn’t worry about going to different expensive items to reduce weight.. I’d look into something lighter more manageable.
My 93 FXSTS is down to just at 600lbs with half a tank of gas and oil in it. It started at 636 lbs.
The 36 lbs of weight difference isn’t enough for you I wouldn’t think.
I shaved weight, hollow chromoly axle, chromoly bolts wherever I could (all brake bolts front and back, aluminum rear sprocket, Aluminum rear hub and rim. Lithium battery. Front steel hub and rim though, that’s maybe 3-4 lbs I could save. The rear swing arm could be replaced with a Boyd Cottington if I ever found one. Maybe another 4 lbs.
Old Sep 4, 2025 | 09:12 AM
twoglides13's Avatar
twoglides13
I avoid gravel of any shape or size like the plague that it is!!!! One slip of the foot and you're on your ***, and it is not very paint friendly!!!
Old Sep 4, 2025 | 11:34 AM
RANGER73's Avatar
RANGER73
I think you guys missed the joke, but I'll play.
Put helium in the tires instead of that heavy Texas air.
Old Sep 4, 2025 | 11:50 AM
YZR's Avatar
YZR
But you would still need 40lbs of it! 🤣
Old Sep 4, 2025 | 11:58 AM
Boat Bum's Avatar
Boat Bum
Old Sep 4, 2025 | 12:07 PM
Max Headflow's Avatar
Max Headflow
Pave part of the driveway?
Old Sep 4, 2025 | 12:17 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Put a reverse gear on it. Cheap kits from ebay should do well enough.
Put a reverse on my Road King some years ago for the same reason. Made it a much more manageable bike, for me.
