Stalling
I was having a problem with the bike stalling, which I thought was related to a throttle adjustment because I just had to rewire my turn signals inside the handlebars. I had the rear end jacked up for an unrelated reason started the bike was gonna let it idle for a while and see if I had a vacuum leak using the brake cleaner test Bike was in neutral idling, and I noticed that the rear wheel was turning, and when I stopped the rear wheel from turning the bike stalled. Is this normal? If not, what’s the issue?
How much effort did it take to stop the rear wheel....??
Many bikes will spin the rear wheel in neutral due to clutch plate drag, but stopping the rear tire usually takes little effort and won't cause a stall.
However, any bike I've ever ridden with a properly adjusted clutch, will stall if you let the clutch out, with the brakes on.....
Have you adjusted or done anything recently to affect the clutch adjustment?
It could be that your clutch needs adjusting...
If not the clutch, IMHO, there is not enough info for a good guess at a diagnosis.
We could use more info about the conditions that lead to the bike stalling; how and when, hot or cold, moving or stationary, accelerating or decelerating, etc, etc
Also what work has been done recently. You mention some handlebar rewiring, and that you had the rear wheel jacked up for an "unrelated reason". Other issues that you were working on, and/or mods you have recently done could be important...
We are not there to see what you see, hear what you hear, and know what you have done, checked, or tried in order to fix the issue.....
Help us help you....
I have a couple ideas, but they would depend on the bike you have.
Let's get the basics down, so we all know about the bike....
Could you give us the year/ model/ carb or EFI / mileage / any engine mods...?
I was surprised to see your 2014 still has an IAC (idle Air Control) module. I thought they had switched from those by 2014... must have changed on just the touring "A" Twin Cams.
A bad or dirty IAC will cause your bike to stall as reported, and have hard starting issues. I don't recall it causing the bike to completely fail to start....
In any case, that's where I'd start with your reported issues. You can clean the plunger and its seat in the induction module that controls air at idle. You can also check to see if it is functioning altogether.
A quick search on this forum, or a general internet search, will give the directions for a cleaning and/or operations check. Both pretty easy...
Report back what you find...
