wanting to bring stock handlebars back an inch or so...having trouble finding something that fits this year/model isnt easy.. looking at REX pull back blocks, & or various 3 1/2 '' riser but cant get a definate answer as to weather they will work/fit. Looks like there is a couple inches extra wireing..
any ideas???
any ideas???
I've been looking for MONTHS for same thing with same results..I've found same stuff ...same results, nothing definite , not ready to take a chance buying wrong parts yet..I figure something will pop up sooner or later ..
You wrote Rex, but did you actually mean Rox? If you meant Rox, I can tell you they fouled my tank with just a little pullback. I think I had 2 or 3 inch adjustable Rox pieces. So I would say no, they dont work.
There is some allowance in the wiring. A bit less in the clutch cable and brake hose. Youve enough for 2 inches. By 3, its a problem. By 4 its a no go.
Its a lot of money, but I ultimately went with Helibars. A lot of time and twiddling to get it right, but in the end, it was worth it, for me.
Get whatever you want there all about the same mounting. Softail deluxes had quite a bit of pullback, just like everything else you change though, you have to check for clearance. I have a softail deluxe and didnt like all that pullback but did want a little. I got some FXR risers that I liked,bolted right on. very close to speedo though because its not as high as stocker deluxe was
