2025 Heritage Jump Start
Old Dec 30, 2025 | 04:50 AM
SMR65's Avatar
SMR65
Congrats on your purchase. Thats a great looking Heritage. Enjoy.
Old Dec 30, 2025 | 05:52 AM
soca's Avatar
soca
I have a 2025 LRST. I have previously owned a 2021 Heritage and. 2019 Lowrider (and other Harleys). The 2025 has been redesigned and is not like the previous M8 models. Much of the comments you have received is no longer accurate. It is not as easy to get to the battery or starter to jump the bike. The simplest way to jump a 2025 is to buy a Noko jump box ($100 on Amazon) and a Noko accessory cable ($10 on Amazon). Attach the cable to the battery and leave it rolled up in the side cover for emergencies. If a jump is ever needed, it only takes 5 minutes. Also, buy a service manual. It has instructions on how to get to the battery. You don’t want to have to deal with a dead battery on the side of the road. Soca
Old Dec 30, 2025 | 07:10 AM
crowbar22's Avatar
crowbar22
5th Gear
good to know. Thanks!
Old Dec 30, 2025 | 07:25 AM
crowbar22's Avatar
crowbar22
5th Gear
thank you! Really looking forward to putting some miles on it.
Old Dec 30, 2025 | 07:32 AM
Bone Doc's Avatar
Bone Doc
I've read the instructions on how to replace the battery on a 2025 model. It blows my mind, but not surprise me, that the engineers would make it that difficult to change the most common maintenance item on a motorcycle.
That BS is not limited to Harley. My friend had a Toyota Prius and needed to change a headlight. He had to practically remove half the front end just to get to the lamp assembly.
My opinion is that this is by design, aka on purpose. They make it so difficult that many people will just go to a dealer to have any maintenance done.
Old Dec 30, 2025 | 07:46 AM
crowbar22's Avatar
crowbar22
5th Gear
i completely agree on both counts. It’s absolutely ridiculous and it seems obvious that they are doing this to ensure a higher service revenue stream for their dealers. It’s the wrong way to solve the “dying dealership” problem. This will further alienate their loyal “true biker” customer base that loves to maintain their own bikes. I don’t fall into that category but I like to save a few bucks by changing fluids, lights, batteries, etc myself, and have the ability to do a jump start without a complicated upgrade process. And even on my 2016 Dyna it’s been easy to do all that.
Old Jan 2, 2026 | 07:48 PM
Kenelz's Avatar
Kenelz
Yep, the battery is a real pain to get at. I don't know where else they could put it, the problem is the mono-shock that they had to tuck it under.
I added the NOCO boost cable pigtail, it's a much thicker cable than the charger pigtail, seems I paid about $30 when I got mine, they must have dropped the price. I fed it down on the right side under and below the right side cover.
Old Jan 2, 2026 | 08:07 PM
Rounders's Avatar
Rounders
Originally Posted by foxtrapper
Even if it doesn’t start, two of you should be able to run it up onto the trailer pretty easily.
Some trailers are very steep. You are not pushing up mine and may bottom out frame.
Could build a ramp,if needed. I should build one for mine so I have it when needed
Also keep in mind could be icey driveway. Which will be tough with out with it running or with it running
Been thinking should add pigtails for jump packs. If they make converter could replace tender plugs
What about 7/16 boxed wrench as an extension to get jump pack on starter? This goes directly to battery. Wrap it in tape. Double check size
I believe pull seat and dick with cover on battery may be best option.
Put in trailer mode or just pull main fuse
Old Jan 2, 2026 | 09:21 PM
crowbar22's Avatar
crowbar22
5th Gear
thank you for your input. Yep, the driveway was icey, and hadn’t been shoveled. I spent a lot of time clearing the driveway and then putting sand down for additional traction. I had the local HD dealership come out and pick it up and bring it to their facility for storage. It started with no problems. Owner had set up the tender properly. I’ll ride it home in the spring. After I get it home I’ll consider options for jump start ability. If I can’t get something on the starter easily I’ll probably add a pigtail in the spring. I like the idea of that but I’m not looking forward to the task. Good way to get to know the new bike I guess.
STLCHUCK
Electrical/Lighting/Alarm
Dec 26, 2021 10:07 AM
katn0
Jun 28, 2015 08:36 AM
A1ACruiser
Nov 15, 2013 08:52 AM
Trav
Mar 12, 2012 08:17 PM
megabutter
Apr 25, 2009 08:28 AM
