98 evo stripped head studs
Old Jan 22, 2026 | 06:38 PM
Toneloco's Avatar
Toneloco
Default 98 evo stripped head studs
Well working on my evo 98 fatboy as I begun t o torque them one stud which I previously installed a time sert it spun what if any good or best thread lock is out there any and all referrals welcomed
Old Jan 22, 2026 | 07:16 PM
Ohio HD's Avatar
Ohio HD
Sounds like you stripped the case where the time sert was installed. Time to pull it apart and weld. Job for a machinist who has aluminum welding capabilities.
Old Jan 23, 2026 | 11:41 AM
Max Headflow's Avatar
Max Headflow
And people say time serts are the best...
They do make oversized timeserts.. Give that a try. When you cut the new treads use Tapmagic aluminum cutting fluid.. The main reason for either a timesert or helicoil failing is improper cut threads.
Old Jan 23, 2026 | 03:15 PM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
I agree with Mr. M. I would give it a go again with a slight over sized Sert. I would also use red Loc-tite, or one of the help will free over first heavy duty loc-tites. I can't remember the #, but can get it for you if you want. There is one that is the true FOREVER bastard of all loc-tites.
Old Jan 23, 2026 | 08:09 PM
Max Headflow
If using a thread locker use red 277 or green 260. Both are rated to 450F.
Old Feb 1, 2026 | 03:05 AM
Toneloco's Avatar
Toneloco
Default Stripped evo cases
I had some good luck at our new casino near Taft hard rock I ran out with 1200 bolted out and considering I put like 700 in the motor top end cam lifters gasket bored 30 over I decided to purchase a evo 1000 bucks hopefully get hit agian at you guessed it casino bound and build a chopper next
Old Mar 8, 2026 | 11:48 AM
Toneloco's Avatar
Toneloco
Default Studs once more
so I decided to use my new pistons and barrels on the evo i purchased just doing a prayer before i do it only because of the ast time the stud stripped out thank you in advance
Old Mar 13, 2026 | 03:23 PM
tar_snake's Avatar
tar_snake
Grammar - punctuation and capitalization are our friend.
Old Mar 13, 2026 | 03:28 PM
Ed Ramberger's Avatar
Ed Ramberger
If the cases are white with what looks like corrosion, many times the metal where the studs go is very weak and will pull.
Old Mar 14, 2026 | 12:58 PM
Toneloco's Avatar
Toneloco
ok thanks good to know
86glider
EVO
15
Jun 10, 2022 08:22 AM
horslips
EVO
May 24, 2022 08:49 AM
teal379
EVO
13
Jul 19, 2021 05:05 PM
bluharley
EVO
Jul 12, 2014 04:22 PM
cthecope
Exhaust System Topics
Dec 5, 2010 10:00 PM
