which lowering kit?
Old Sep 13, 2007 | 04:45 PM
tattoome's Avatar
tattoome
Default RE: which lowering kit?
ORIGINAL: grimm
if any of you guys have switched from the burnout kit and want to get rid of it, let me know. i tried to buy the kit last month, but apparently they are nowhere to be found. i'm not just talking about the kits, either....the whole company! the website is no longer there and the company i went through to get it said they were no longer able to carry the kits. didn't give me any more info than that.
anyway, like i said, if you wanna get rid of it let me know.....
grimm [align=right]
[/align]
I just purchased this kit today from JP Cycles. I believe it is the same as the Burn Out kit. At least that's what I'm told. $99.00 isn't too bad.
http://www.jpcycles.com/productgroup...All&page=1
Old Sep 13, 2007 | 04:49 PM
Marsh's Avatar
Marsh
Correct me if I'm wrong, but that appears to only lower the rear. Right?
Marsh
Old Sep 13, 2007 | 04:50 PM
grimm's Avatar
grimm
that's it! thanks! i'll see if i have better luck with JP....
Old Sep 13, 2007 | 04:52 PM
grimm's Avatar
grimm
ORIGINAL: Marsh
Marsh
you are correct. only the rear is lowered with this kit.
Old Sep 13, 2007 | 09:19 PM
Bwareofprplhaze's Avatar
Bwareofprplhaze
the 422s are great and i've also had good experience with the progressive cruise control fork lowering springs recently installed for the front too
Old Sep 13, 2007 | 09:38 PM
bensonjv's Avatar
bensonjv
ORIGINAL: MICHALISLARNACA
Do not use the lowering kits. They put too much strain on the shock bolts and keep bottoming out. I had one on my 2007 fatboy and I had to buy the HD OEM part which lowers the bike by 3/4' not much but you get the looks but most important the ride quality
That a pretty heavy duty negative endoresement to make. There are a lot of people using lowering kits on stock shocks with no reported loss of ride quality, excessive strain on shock bolts, or bottoming. I know aftermarket shocks have definite advantages over stock but that doesn't negate the benefits of installing less expensive kits on stock shocks.
Did your shock bolts break? What brought you to the conclusion that all lowering kits are bad?
ORIGINAL: grimm
grimm
Interesting.
legendzzz
Aug 31, 2019 10:58 AM
Shadetree Prez
VRSC Models
Jul 16, 2010 06:57 AM
60wt
Jun 15, 2009 06:39 PM
MAX EVO
Dec 9, 2006 02:27 AM
The King
Sep 28, 2005 09:32 AM
