starter /bendix/jackshaft not engaging
Old Mar 23, 2026 | 07:09 PM
evilokc's Avatar
evilokc
6th Gear
Default starter /bendix/jackshaft not engaging
when i got this bike a year ago the starter was grinding badly until it finally gave up completely. i replaced the starter. It started great for about 20 starts over the winter then began grinding and now the Bendix isn't popping out far enough to engage the flywheel to spin the engine. Im researching but if anyone has delt with this i would appreciate the heads up to save some time. I charged the battery to verify that wasn't the issue. the starter is new with around 20 starts on it, the jackshaft is not new. its the original from 1998. the Bendix teeth do have some damage on them but that's not what's causing this. i tried to add a video and its not working. nothing else is so why should the video? I read that the spring behind the jackshaft can get weak and cause this. when i replaced the started i reused the old spring. anyone had that happen? i removed the spring and its very easy to collapse.
Old Mar 23, 2026 | 07:14 PM
evilokc's Avatar
evilokc
6th Gear
im trying to get the video up
File Type: mp4
Old Mar 23, 2026 | 08:10 PM
Max Headflow's Avatar
Max Headflow
The gap between the pinion and ring gear looks too large. You may have torqued the Bendix bolt too tight and bent the snap ring in the coupling.
Old Mar 24, 2026 | 07:26 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Or maybe the coupling is in backwards??
Old Mar 24, 2026 | 10:58 AM
evilokc's Avatar
evilokc
6th Gear
i put it back the way i pulled it off but i have a suspicion that it may be reversed.
Thebikerpiper
Jun 28, 2022 12:32 PM
dmpjr
Dec 8, 2014 05:22 AM
FXD_noob
Oct 20, 2013 03:27 PM
sunup420
EVO
Feb 7, 2010 11:58 AM
Lons 77
11
Aug 30, 2008 01:46 PM
