Starter issues
Old Mar 24, 2026 | 05:41 PM
Dlee's Avatar
Dlee
Stage III
Default Starter issues
I'm at wits end .. I have a 95 heritage Softail I bought a new starter and put on it everything was fine for about 20 starts went on a trip to Alabama on the way back started quit working got it home took it apart it appeared to be the starter clutch drive so I got a new one and put in it but it still is not on the bench it seems to be working fine soon as I put it on the bike not so much it's throwing out the Jack shaft but it's not spinning and it sounds like it's spinning in the motor I've inspected all the gears and all that kind of stuff they're all seem to be working right I just don't understand what's going on it's not spinning after it throws it out even though it sounds like the motor spinning starter motor
Old Mar 24, 2026 | 05:44 PM
CoolBreeze3646's Avatar
CoolBreeze3646
How old is your battery? Have you had it load tested? Could be it is not putting out enough amps to spin the motor over. Does not take much amps to spin a starter over without load.
Old Mar 24, 2026 | 05:46 PM
MURPHCC1's Avatar
MURPHCC1
Bets on the battery!!!
Like he said, have it load tested!
Old Mar 25, 2026 | 11:01 PM
Dlee's Avatar
Dlee
Stage III
Thanks I will have it tested soon as I get home hope y'all are right.
BlackPearl#1
Jun 1, 2022 06:07 PM
doug62
Jul 7, 2018 05:20 PM
TexasCowGrower
Feb 18, 2011 02:50 PM
lebert
Aug 7, 2010 07:03 AM
plya5632
Welcome Area Only
Oct 16, 2004 08:32 PM
