Fuel gauge wrong reading...
I'll measure the resistance at the top position of the float so that I'll lift the float through filler hole and than we'll see. If it will be to low than it is a probably bent arm...
If the issue appeared right after the "work", then it could be a problem with the float's range of motion..
But if it took awhile for the issue to appear, then range of motion is less likely..
Keep us posted on what you find out...
Good luck with the repair
I don't use it anymore. It is nice to show almost full in case I forgot to reset tripmeter.
But it does sound like the slider is getting a signal through its range of motion. It just may not be the correct resistance signal, meaning corrosion could still be a factor. I do not know if there is a spec for that in the manual - Have you tried to look that up?
If contacts get dirty the resistance goes up. In my case the resistance is lowered...or there is something that I don't understand...
You report that the sender measures in spec, yet when attached to the gauge, the gauge isn't reacting properly to the signals. Sure sounds like the wires/connectors somewhere between the sending unit & fuel gauge have an issue, or that maybe the gauge itself has an issue.
I have to admit, I am not an electrical guru. I am unsure if the gauge itself interprets the changes in resistance, or the ECM does that and then sends a signal to the gauge... On the carb bikes I believe it's the gauge that does the interpretation, so it's probably the same with the EFI bikes (until the BCM was introduced).
Just some food for thought....
Have you inspected the fuel gauge connector where it plugs into the wire harness at the frame backbone, under the tank? It's not always easy to get to and manipulate with the tank on the frame, but it's doable. Have you inspected the fuel gauge wires that come out of the bottom of the tank to the connector on the harness for signs of chafing?
When you inspect the connectors for corrosion, also inspect the connector pins. They can get bent causing connection issues. Also some of them can become dislodged in the connector housing, causing them to slide back (out) when the connectors are put together, also causing connection issues.
