Pinch Bolts snapped
Old Feb 13, 2013 | 03:53 PM
Alain's Avatar
Alain
could it be that the clunking he was hearing after replacing the pinch bolts could have been coming from the fork stem nut being too loose?
Old Jul 2, 2015 | 03:39 PM
phortwenny's Avatar
phortwenny
Stage III
Default Two more broken Pinchbolts
2005 Heritage 64,000 miles and one minor front end collision...
Pinchbolts were broken I will replace with grade 8
Old Aug 17, 2020 | 12:38 PM
DIY _GUY's Avatar
DIY _GUY
Apologies for raising an old dead thread, but damnit, this is so wrong and so unsafe. Why doesn't HD have a safety recall on this problem yet.
2011 Heritage Softail Classic with 32,000 miles. I have never touched this area of the bike, since new... hence, I did not over-torque or contribute to this fault... I had the same issue this past weekend. Major fork oil leak. So made it home 200 miles later, tore it all apart, to notice the one fork tube totally unscrewed itself and fell down 3 inches. Then looked closer and saw both pinch bolts sheared off. Guess, I will need to put in grade 8 bolts to fix a known HD safety issue. HD should be held liable for these types of safety issues.
Old Aug 17, 2020 | 12:53 PM
DIY _GUY's Avatar
DIY _GUY
oops, correction. My pinch bolts on the 2011 were already factory installed Grade 8 bolts. There was a bulletin out for this known issue. Guess, I will just put in new Grade 8 bolts, and watch out for potholes better.
File Type: pdf
Old Aug 17, 2020 | 01:12 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Check your service manual, most state that critical fasteners must be checked for proper torque at specified intervals, which is normally 1k, 10k and every 10k afterward.
Old Aug 17, 2020 | 01:18 PM
Uncle G.'s Avatar
Uncle G.
I had a pinch bolt break twice on my '94 FLSTN, always on the left (brake side). After the second time, I bought a sack of 7/16-20 grade 5 bolts and replaced them every other year as part of the routine service. I never had another one break.
I used grade 5 bolts instead of grade 8 because if I broke a grade 8, it would be much harder to get an easy-out into a grade 8 bolt.
06strglide
Aug 20, 2020 05:27 PM
dyna2008
Jul 18, 2018 09:52 PM
msgtbob
Mar 4, 2013 10:39 AM
sharkysw9
Mar 12, 2011 09:59 AM
WI_Jeff
Welcome Area Only
13
Jan 18, 2008 07:06 PM
