Fatboy headlight on FXST
Old Nov 29, 2005 | 07:28 PM
JeffD's Avatar
JeffD
Default Fatboy headlight on FXST
Has anyone here installed a Fatboy headlight on a Softail Std? What is needed for the conversion, besides the housing, and lense?
Jeff
Old Nov 29, 2005 | 07:54 PM
oldgeezer's Avatar
oldgeezer
Default RE: Fatboy headlight on FXST
Don't know for sure but I'd suspect the mounting is different since the Fatboy is an FL front and the Standard is an FX.
Old Nov 29, 2005 | 07:55 PM
MegaHDman's Avatar
MegaHDman
Trim panels and some odd hardware, is that what you really wanna do? Would look kinda silly with the standard wideglide fork assembly.
Old Nov 29, 2005 | 08:00 PM
JeffD's Avatar
JeffD
No I do not want the trim panels, just the 7" headlight.
Old Nov 29, 2005 | 08:31 PM
wmiconi's Avatar
wmiconi
Post a pic when your done!
Old Nov 29, 2005 | 08:37 PM
MegaHDman's Avatar
MegaHDman
ORIGINAL: JeffD
A 7" headlight? Not many street lights in your area?LOL! Do you know how big a 7" light will look on those wideglide forks? Below is a 5" assembly on standard wideglide forks.
I'm just curious if you have visualized one, or are you changing out forks? I would love to see pics of your vision once its done, but I must say I'm skeptical. Tell us a bit more what your idea is.
Old Nov 29, 2005 | 08:53 PM
JeffD's Avatar
JeffD
Well... I did see a Softail Std, in NC that had a Road King Nacelle adapted to a FX front, and it looked VERY cool, but for what a Nacelle goes for it's out of my budget. I have a new visor trim ring for a Fatboy, and mocked it in place on my bike, and it will look fine. I don't think it will give off much more light, but I want something DIFFERENT. No there are not many street lights were I ride.LOL.
The FB light does mount the same way a Std FX light doesBTW.
Old Nov 29, 2005 | 09:08 PM
pococj's Avatar
pococj
Jeff, I replaced the 7" light on my Heritage Sloptail with a 5" model. The mounting stud was in a slightly different location and I had to make up something to allow the light to sit properly. I ended up using a piece of square stock, cut, drilled, & tapped as necessary, and added to the original mount.
Old Nov 29, 2005 | 09:59 PM
wmiconi's Avatar
wmiconi
ORIGINAL: MegaHDman
ORIGINAL: JeffD
Mega, What size is that front tire. i am looking for a fatboy rim for my FXST. Looks good.
Old Nov 29, 2005 | 10:02 PM
MegaHDman's Avatar
MegaHDman
Its an 18x3.5" rim with a Venom R 130/70-18 radial tire.
