white wall Tires
Old Sep 21, 2007 | 04:18 AM
softaildhd's Avatar
softaildhd
2nd Gear
Default white wall Tires
Hey guys is there anything that I can put on my white wall tires that will keep the brake dust from clinging to the tire and what is the best and easiest thing to clean them with.Thanks Jeff
Old Sep 21, 2007 | 05:20 AM
Trailfndr's Avatar
Trailfndr
Default RE: white wall Tires
Mr. Clean Magic Erasers do a great job o whitewalls. Easy to use, and no fumes. Get at any Grocery Store in the household cleaner isle
Old Sep 21, 2007 | 05:28 AM
mitcht's Avatar
mitcht
Yeah, I think if you do a search you see Erasers and Wesleys Bleach white as popular methods, but recently i changed my brake pads away from HDs to Lyndell Z pads.........not only do they brake perfectly, they are DUST-LESS and I can now see a huge difference in the amount of brake dust even after long rides.....hardley any with the new pads.
Old Sep 21, 2007 | 07:46 AM
vabubba's Avatar
vabubba
I just quit using my brakes
Old Sep 21, 2007 | 07:53 AM
RACKnRAIL's Avatar
RACKnRAIL
I also use Mr. Clean Magic eraser sponges. They truly are magic.
Old Sep 21, 2007 | 08:53 AM
commander112's Avatar
commander112
Ditto!
Old Sep 21, 2007 | 09:21 AM
tmitchellof PG's Avatar
tmitchellof PG
ORIGINAL: mitcht
Ditto.
Old Sep 21, 2007 | 09:34 AM
seaflea's Avatar
seaflea
I use scrubbing bubbles on just about everything.
Old Sep 21, 2007 | 11:51 AM
spikehyre's Avatar
spikehyre
Ditto on Mr. Clean....but Mother's now markets a chrome spoke cleaner...spray on rinse off....that cleans the brake dust off.....but Mr.Clean will make em snap....
Old Sep 21, 2007 | 12:09 PM
OldBoldPilot's Avatar
OldBoldPilot
Just as an alternative solution, I spray some Simple Green from the plastic spray container onto a rag and just wipe them clean, then follow up with a damp rag. Lots cheaper than Mr. Clean, and not as messy.
I also run Lyndall-Z pads, which do indeed make a huge difference not only in brake dust but in stopping power as well. At about $35 per set, they're one of the cheapest and best mods out there.
