EFI vs Carb
I'm considering a new 2006 FLSTF. What are the pros and cons of going with EFI? I know the maintenance is higher on fuel injected engines, but performance should be increased. What are other considerations? At most I will probably only add HD slip on slash down mufflers and change the stock wheel option.
I appreciate any thoughts. I am not mechanically inclined enough to really know the advantages beyond the small performance improvement.
FI, offers on average easier starts and a smoother running bike through more precise metering of fuel. Downside (this can change as technology comes to market) to FI bikes is that if you do alot of motor upgrades, you will need to reflash the computer to update the ignition and fuel maps of the bike. Many times, the new uploaded maps will not work correct for your bike. There are options like going with aftermarket fuel and ignition controllers, but again you need to be proficient at understanding how they run.
IMO FI bikes have more "potential" upside to them. But currently the ECM's for the bikes are rather limited and there are only a small number of competent tuners that really know how do dial your ECM for maximum performance with the aftermarket options available.
For the DIY tinkerer: The advantage goes to a carb'd bike.
For the Just ride and not worry type who doesnt plan on doing alot(or no engine mods) of engine mods, then the advantage can probably go to FI.
As technology develops, and dealer/ end user compentency increases, the edge will more and more over time favor the FI bikes.
'cause that's what I do also. I think there is a thread on the forum supporting the "enricher to start and throttle lock the grip, push enricher in"'. Less plug foul...longer engine life etc.....anyway, I bought into it. Thanks for listening..
