Heritage Engine sound?
Old Oct 28, 2007 | 09:35 PM
bankerron's Avatar
bankerron
Default Heritage Engine sound?
I have a 96 Heritage and the last couple of days I here this sound on the left side near the bottom when setting at idle. It sounds like a lifter sound but it is on the left side and like I said near the bottom. Any ideas???? Thanks!!!!
Old Oct 28, 2007 | 10:25 PM
FXSTI Guy's Avatar
FXSTI Guy
Default RE: Heritage Engine sound?
Hard to tell without hearing it first hand...from the description you've given I'mguessing this sound you're hearing is coming from the primary/clutch area ???
Old Oct 29, 2007 | 08:40 AM
Mikey 1450's Avatar
Mikey 1450
Check your primary chain for correct adjustment. Also, if the bike has high mileage, the compensator can wear and leaves a little slop between the 2 pieces. When this happens you can hear it and feel it.
GoCards82
Jun 27, 2011 05:11 PM
JD07
May 17, 2011 12:54 PM
robdavis305
Jun 23, 2010 07:37 AM
softtail93
Aug 8, 2007 08:09 PM
vinnyflstc
Exhaust System Topics
16
Feb 14, 2007 05:36 PM
