422's Initial Setup
Old Nov 29, 2007 | 04:26 AM
Stevenacnj's Avatar
Stevenacnj
Default 422's Initial Setup
I got my 422's from Phat delivered yesterday. These shocks are fine looking. Read over the supplied directions last night and have a few questions:
1. The shocks come from the factory set to the softest ride?
2. I am 6ft 200lbs& ride solo - want a mid type of ride not too soft not too hard - where should I start out? Also to stiffen ride will use supplied wrench and adjust counter clock wise?
3. I would like to achieve a 1" lower rear. About how far out should I start with the gromet adjustment? I am thinking like half way of total adjustable thread?
Thanks in advance.
Old Nov 29, 2007 | 09:11 AM
rockerhead's Avatar
rockerhead
Default RE: 422's Initial Setup
I don't know where they start. However from highest preload to lowest is 8 turns. So screw them all the way from one end to the other so you can start in the middle (4 turns). Remember that on the highth adjustment that longer is lower.
Old Nov 29, 2007 | 12:48 PM
XARAN's Avatar
XARAN
I also got my 422 from phat.
I am 225lb and ride solo most of the time. I adjusted them 2.5 turns out from the factory setting . (counter clockwise towards the front of the bike, remember that you are extending the springs to increase the preload).
I have my bike about 1 inch lower than stock and that worked out to be a little less than half way on the adjustment.
Hope that you like them as much as I do on my bike.
Old Nov 29, 2007 | 03:57 PM
Stevenacnj's Avatar
Stevenacnj
Thank you for the helpful info.
Bluraven
Jul 26, 2023 03:34 PM
rs87277
Dec 17, 2012 02:30 PM
HimeHog
Mar 19, 2008 09:18 PM
shiyfire
Apr 29, 2007 03:33 PM
scubabike420
Jan 7, 2007 11:40 AM
