Amsoil Question
Old Dec 11, 2007 | 05:25 PM
eravo's Avatar
eravo
Default Amsoil Question
I'm using Amsoil for my engine and I want to use it in my transmission. What type of Amsoil should I use? I live in Florida...
Old Dec 11, 2007 | 07:25 PM
nvsteve's Avatar
nvsteve
Default RE: Amsoil Question
I use the Amsoil Severe Gear 75-90. It's a synthetic gear lube.
You may want to consider the 75-140.
Old Dec 11, 2007 | 07:53 PM
rjmac53's Avatar
rjmac53
Use the 20 -50 in all three holes - the best way to go !!!
Old Dec 11, 2007 | 08:07 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Down where you are in FLif you do a lot of slow stop and go riding in the heat of summer I would vote for the 75-140W.
The 75-90W stuff is fine for the rest of the year or you rarely do the slow stop and go junk.
Old Dec 12, 2007 | 12:14 AM
WARG's Avatar
WARG
Citoriplus, I am currently running the severe gear 75w90, but can only find the 75w140 locally, would that be a good substitutue if that's all I can find?
Old Dec 12, 2007 | 06:35 AM
If that's all you can find, go for it.
Worst thing that will happen is that its a tad harder to shift until it warms up when its cold out.
With modern chemistry at work, I doubt you'll notice any realdifference.
Remember that the 75 in 75-140W or 75-90W is supposed to mean that the oils viscocity is the equivlent of 75W straight weight dino oil when its cold. So in theory they will behave exactly the same way. Its only when the temps start climbing to the stratosphere that the 90 or 140 part becomes important.
Besides as a last resort you can always order it on line. Might take a week or so to get there. But because the tranny oil doesn't see any of the byproducts of burning fuel.
Changing it"exactly" on time isn't quite as criticalIMHO as doing the engine oil.
Just look at the dip stick, if the oil looks clean its probably fine for a week or so and unless you plan on going another 5 or 10K in that time frame or know there is a lotof bits of metal floating in it.
Personally I wouldn't have a problems leaving it in theretill the new stuff arrives. And I'm one of thoseanal loons when it comes to changing engine oil.
I changed my engine oil 4 times in the first 4500 miles instead of the usual twice, but I only did the primary and tranny twice.
Old Dec 12, 2007 | 07:56 AM
tk353's Avatar
tk353
I use the Amsoil Severe Gear 75-140.
Old Dec 12, 2007 | 10:18 AM
WARG's Avatar
WARG
I did my service at 1000, 4000, and getting ready to do it again at 7000 (just fluids and filter). So far I really like the amsoil.
Old Dec 12, 2007 | 08:26 PM
tk353's Avatar
tk353
ERROR
I use Amsoil in the engine. big improvement. I use Bel Rey gear Saver in the trans.
Old Dec 13, 2007 | 12:06 AM
RandyM1911's Avatar
RandyM1911
Check out the "Oil & Oil Related Topics" section of the forum. Lots of good stuff there. Here's a link to one of the threads/polls on tranny oil.
https://www.hdforums.com/m_90568/tm.htm
1320str8_liner
May 5, 2012 03:00 PM
davlyo
Sep 21, 2010 07:57 AM
Road King Craig
Oil Archive (no new posts)
Apr 14, 2008 03:48 PM
mndemohead
Jul 9, 2006 01:28 PM
06glide
Jun 17, 2006 12:05 AM
