TMax and Softail
Old Dec 17, 2007 | 12:56 PM
sportncruise's Avatar
sportncruise
Default RE: TMax and Softail
ORIGINAL: tlb
I have an 06 Fatboy without any oxygen sensors in the exhaust, V&H Bigshots, do I have to get a new exhaust or can I just drill a hole and install some kinda keeper?
ORIGINAL: SpringerDude
I just installed mine on an 06, so my biggest chore was routing the oxygen sensors. Programming the TMAX isn't too bad. I thought the directions were a bit confusing, so I called their tech support line and they walked me through it. Oh, and the only real complaint is that there isn't much clearance for bolting down the unit. I ended up using three bolts instead of four. but it's on there pretty well.
You will need to purchase the bungs for the o2 sensors to go in and have them welded to yourV&H exhaust.Zippers part # for bungs 272-200
http://www.thunder-max.com/Support/I...on%20V2007.pdf
If you want to look over the instructions before the install here they are on .pdf.
Old Dec 17, 2007 | 02:43 PM
Batbuds's Avatar
Batbuds
OK, UNCLE!!
I got the front O2 sensor just fine. I cannot get ANY tool between the real cylinder fins and the frame brace to get the rear sensor out!
ARGH!! I have a friend on the way and we will try a crows foot socket from the right side of the bike. If this does not work, it looks like I may have to take the rear exhaust tube off and replace the sensor that way. What all is involved with this???!@(#*$_??
Oh, the audible alarm module does NOT like the battery to be disconnected!! LOL
Oh, and another, I was able to get 3 of the 4 ECM bolts to come loose with no issues...
There is alwaysONE f'in one that will not cooperate!!
Old Dec 17, 2007 | 03:43 PM
sportncruise
ORIGINAL: Batbuds
OK, UNCLE!!
Did you put the exhaust on yourself?
If not getting the small nuts off of the exhaust port can be difficult but getting them back on even worse. I ended up using a screw driver and taped the nut to it to get it started. Getting it off I used a swivel socket. They say use new crush washers but I reused mine and no leaks.
Removing the guards off the exhaust gives a socket more room to get to the nuts.
While this way seems more time consuming, to me it is easier knowing the 02 sensors are on all the way.
Good luck.
Old Dec 17, 2007 | 03:56 PM
rbabos's Avatar
rbabos
I've got one coming for my custom also. It would seem that giving yourself 8 hours of install as opposed to 1 should keep me from going bullistic.
Ron
Old Dec 17, 2007 | 04:21 PM
PhatDLX's Avatar
PhatDLX
Will make my decision this week.It's gonna be the T-Max or the simple Fuel Pack.
Old Dec 17, 2007 | 05:46 PM
Batbuds's Avatar
Batbuds
Ok... installation is complete... here are my notes! LOL
On a Springer Classic, remove the left side of the exhaust.... it is a simple slip joint on the crossovers.... be cautious of the little 'o' ring seal that will come off on the side you are removing.... you can then loosen the seat post where the ignition module is mounted. This will free up enough room to allow a o2 sensor tool in (with a LOOOONG extension)....
other than the tight quarters for the tool on the rear cylinder, the process is very easy, and would have taken about 2 hours of very cautious, read the manual, then re-read... study the pictures, etc. time.
I will let you know more as time goes by!
Thanks to everyone for their help and encouragement.
Old Dec 17, 2007 | 06:29 PM
cagao's Avatar
cagao
hey batbuds, does your bike has the oem security system? if so, did you have to do a learning procedure for the security module?
RideSafe!
Old Dec 17, 2007 | 07:07 PM
SpringerDude's Avatar
SpringerDude
ORIGINAL: rbabos
Ron
Excellent strategy!
Old Dec 17, 2007 | 09:01 PM
Batbuds's Avatar
Batbuds
ORIGINAL: cagao
RideSafe!
Once I reconnected the battery, I had to run through the initialization process on the TMax. During that time, I am sure my neighbors were NOT very happy as the security module reactivated! LOL
I believe I would suggest removing the security module until the initialization is complete and the base load done... THEN reinstall the security module.... just to keep the neighbors and ears happy!
I will do my run ups and checks in the AM and let this thread know how that goes.
Old Dec 18, 2007 | 10:03 AM
Batbuds's Avatar
Batbuds
OK... I am already impressed. When I first started the bike after loading the map suggested by Zipper for my setup (MAP 401 for me), the exhaust sure seemed like it was running rich.... as the bike warmed, that went away to the point that the exhaust almost became odorless... not completely mind you, but nearly. As the head temps increased, the idle stepped down til @ 280 degrees, the idle was about 950. EGO was nearly identical front and back.
Oh, if you install one of these guys, expect smoke at the O2 sensors until the coating and anti-seize burns off! LOL.... that was an initial shock until I realized what was happening! LOL
Once it warms up a bit more outside, I will do some more run-ups....
