Torx setting 07 Fatboy
Old Dec 29, 2007 | 06:56 PM
Pat C's Avatar
Pat C
Default Torx setting 07 Fatboy
I'm planning on installing a rear sprocket cover tomorrow, does anybody have the torx settings for the spocket bolts. Any help would be appreciated on the procedure on removing rear tire. I have a jack is there anything else I would need for this job? I know I should have a shop manual but with work and everything going on I didn't have a chance to get to a HD dealership which is also a good distance from where I live.
Old Dec 29, 2007 | 07:24 PM
kingfisch's Avatar
kingfisch
Default RE: Torx setting 07 Fatboy
55-65 ft-lbs along with 2 drops of Loctite threadlocker 262 (Red) per bolt. Hope this helps. I am assuming you meant torque values.
Old Dec 29, 2007 | 07:58 PM
Sillverback's Avatar
Sillverback
ORIGINAL: kingfisch
55-65 is correct, but I thought the shop manual said to use Loctite 271?
Old Dec 29, 2007 | 08:16 PM
kingfisch's Avatar
kingfisch
Sorry, my bad. Going by 2006 Softail manual. 07 must be different.
Old Dec 30, 2007 | 12:23 PM
renoa18's Avatar
renoa18
No the jack is the best tool and the only thing is you should have two people to put the rear tire back on it is a lot easier with two people instead of one. YOu can do it with one person but I found that with another it makes it go like butter
Krugermeier
Dec 2, 2017 09:19 PM
cop242
Wheels/Tires
Aug 17, 2011 09:00 AM
brihvac
May 16, 2011 07:10 PM
Zinje
Aug 31, 2009 10:04 PM
disom007
Apr 2, 2007 03:33 AM
