O2 sensor, what a location!
Old Dec 30, 2007 | 11:05 AM
Bill918's Avatar
Bill918
Default O2 sensor, what a location!
Just put a new set of V&H bigshots on my wifes 07' Deluxe. The plug to disconnect the rear O2 sensor is located attached to the bottom of the oil tank. Sombitch took me about twenty minutes just to unplug it so I could remove the old pipes. Add another twenty minutes to plug it back in. I hope HD isn't taking their design from the Japanese, I'll have to get smaller hands.
Old Dec 30, 2007 | 11:54 AM
renoa18's Avatar
renoa18
Default RE: O2 sensor, what a location!
Yeah I know where that one O2 sensor is and if you reach underneath the oil tank and un clip it you can reach it real easy. It took me about five minutes to un clip it and then about a minute to take the clip apart. It is a crappy place
Old Dec 30, 2007 | 03:09 PM
JROCKER's Avatar
JROCKER
Yeah kinda shitty spot. that o2was the most time consuming part of the pipe changeover for me!
Old Dec 30, 2007 | 04:36 PM
jm35ny's Avatar
jm35ny
Disconnecting the rear O2 sensor took me longer than the whole pipe swap. Don`t feel bad.
Old Dec 30, 2007 | 06:44 PM
Demkay's Avatar
Demkay
Well, I found that if you put one hand down the empty battery compartment; then one hand under the oil tank, grip both ends with the respective hands, then unclip the holding clip with the right hand's index finger's fingernail and pull at the same time with the left hand's connector; ................. it's a piece of cake to unclip them.
Old Dec 30, 2007 | 10:03 PM
brianp25's Avatar
brianp25
i just left it plugged up and had my dad hold the pipe while i took it out... then i held it while he got the new pipe and put it in.....
Old Dec 30, 2007 | 10:15 PM
08Fatty's Avatar
08Fatty
Ever heard of holding your mouth right. Sometimes I wonder if the engineers read these forums and do this stuff just to get a laugh.
Old Dec 31, 2007 | 01:03 AM
brianp25's Avatar
brianp25
Old Dec 31, 2007 | 01:11 AM
Kevinc's Avatar
Kevinc
Old Dec 31, 2007 | 01:14 PM
Ishman's Avatar
Ishman
Have to be a magician
