Burnout Cycles Kit on 07 Deuce...
Old Jan 9, 2008 | 09:52 AM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Default RE: Burnout Cycles Kit on 07 Deuce...
This looks great. Where did you get the kit and i'm not clear on the items you installed, can you list them? Did you lower the frontend as well?As I don't have a lift, whatshould I expect to get charged in labor from my local wrench?
Old Jan 9, 2008 | 09:56 AM
BoneCrusher's Avatar
BoneCrusher
ORIGINAL: Mother
Thanks, BoneCrusher. Time to bring yours down too!
I'd love to bring it down another inch or so along with the front end.
Old Jan 9, 2008 | 09:58 AM
Mother's Avatar
Mother
Deuces, I think you'd end up paying a couple hundred in labor to have the kit installed. That's why I went ahead and bought a lift and did it myself. That seems like what I always end up doing, weighing the cost of labor against the cost of the tools to do it myself.
I guess Burnout's website is not there any more. I'm not clear on if they went out of business or what. This appears to be the same item though, now offered on J&P's site...
http://www.jpcycles.com/productgroup...ley&page=1
Here's a better pic taken in daylight...
[IMG]local://upfiles/32264/AC95196F516E4A1BB2F2A3775F2BBCA4.jpg[/IMG]
Old Jan 9, 2008 | 04:45 PM
1st HD's Avatar
1st HD
Nice looking bike.
Old Jan 11, 2008 | 01:09 PM
bensonjv's Avatar
bensonjv
The Burnout Cycles kit is a Softail rear shock lowering kit that allows you to lower the shocks without having to use replacement shock bolts. This is a benefit to many as installing replacement shock bolts requires disassembly of the shocks which can be difficult for DIYers without a compression tool or similar mechanism.
You can look at the J&P link picture to get an idea of how the kit works. It's simply a threaded collar that goes over your stock shock bolt, extending it and thereby making it possible to adjust lower than stock.
Rumor has it the Burnout Cycles Co went out of business. You can still find a few of the kits out there. There are also a few similar kits available under different names.
After you have done this yourself you sort of understand why the labor to install is so high. It's not a difficult job in terms of technical ability. It's just a PITA to get at some of the parts. So you sort of have to decide if you want to disassemble enough of the surrounding parts to get good access or simply reconcile that you'll need a lot of extra time to work with the limited space provided to move bolts around.
Old Jan 11, 2008 | 01:12 PM
bensonjv's Avatar
bensonjv
Now everyone will tell you that you should drop the front as well.
When we did the wife's Deuce we dropped the rear 2-3" and then dropped the front (ala Progressive lowering kit) 2" as well. The Deuce really looks good dropped like that.
[IMG]local://upfiles/5927/18B6CCD2204A4915926B09A5F7CBAC48.jpg[/IMG]
Old Jan 11, 2008 | 01:13 PM
bensonjv's Avatar
bensonjv
[IMG]local://upfiles/5927/687E2B3218904ED8A41B83A202A995B7.jpg[/IMG]
Old Jan 11, 2008 | 01:35 PM
Mother's Avatar
Mother
Well, mine's a little bit lower in the back than your wife's, but Istill like the look of the front at stock height. I may end up doing some raked cups and that will lower the front a little bit. We'll see...
Mr Wasabi
Nov 13, 2010 06:43 PM
Brian_D
Jun 30, 2009 01:45 PM
andycg
Apr 15, 2007 12:42 PM
nine11c2
Feb 2, 2007 03:35 AM
Denman SA
Aug 18, 2005 11:56 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
