floating roters
Old Jan 10, 2008 | 07:46 PM
jokr's Avatar
jokr
Default floating roters
does anyone recomend floating rotors over non floating.
pros&cons thank you .
jokr
Old Jan 10, 2008 | 08:47 PM
sonar_chris's Avatar
sonar_chris
Default RE: floating roters
Floating rotors are good for a few things. They dont warp as easily as a standard rotor, the look cool, they wont squeek as much, and they will provide a little better breaking power (although it is probably not noticeable). Having standard rotors Vs. the floating ones isnt a big deal. The difference in stoping power will be minimal at best, but paired with better break pads (lyndell, or EBC organic) or better calipers will provide you the best results. If your looking to switch out your roters for better breaking, then its not going to be worth the money in my opinion, but if you need new rotors, then by all means, they arnt really that much more expensive then the non floating, and if you have any problems with break squeek, the floating rotors should take care of it.
Chris
betho61
Apr 17, 2018 01:38 AM
Hogpro
May 15, 2014 04:53 PM
paud
May 6, 2013 04:47 AM
jaxx1972
Nov 6, 2010 02:22 PM
dogleg
Aug 6, 2007 08:02 AM
