Motion Pro
Old Jan 15, 2008 | 11:50 AM
jrspringer06's Avatar
jrspringer06
Default Motion Pro
Anyone have experience with Motion Pro cables and lines. I am doing a set of 12.5" Chubbys on my springer and found some pretty good prices on motion pro cables.
Old Jan 15, 2008 | 11:59 AM
mulch63's Avatar
mulch63
Default RE: Motion Pro
I never used them and for some reason thought they were medium at best...... don't remember why ? Reading somewhereI quess. But I looked at a set of stainless at a local shop and they seemed heavy and looked real good. Just my 2 cents.
Jim
Old Jan 15, 2008 | 02:15 PM
jrspringer06
Looks like from there web site they are the throttle and idle cables are shipped dry, were others are factory lubed, so I would guess you have to by a cable luber and lube, unless the place that has them listed lubes them prior to shipping.
Old Jan 15, 2008 | 03:40 PM
Agentorange's Avatar
Agentorange
I've used Motion Pro and Barnett and they are both good cables. Actually I thought Motion Pro was made by Barnett.
Old Jan 15, 2008 | 04:58 PM
99embrey's Avatar
99embrey
not sure about those, but I used the Magnum Shielding on my 16" install. Absolutely no problems and they look great!
Old Jan 15, 2008 | 05:49 PM
jrspringer06
Well after reading all afternoon on different cables and experiences, I order the Magnum Sterling Chromite II's. Full set with Novello wire extension set was just over 200 shipped to my door, not to bad since the stealership wanted 300+ for everything and the wire extension set they had had to be spliced and soldered.
Old Jan 16, 2008 | 10:30 PM
Agentorange
Glad you decided on a set of cables and you made a good choice. The full set with the extensions for $200 is a good price. Good luck...
Old Jan 20, 2008 | 05:36 PM
mulch63's Avatar
mulch63
Where did you order from ?
Old Jan 20, 2008 | 05:40 PM
blackend's Avatar
blackend
I have mo-pros on my train and I think they are a good cable. good price to!
Old Jan 20, 2008 | 05:41 PM
metal_mike's Avatar
metal_mike
yep... used them with my 13" flanders install... look and work great!
