Riser bushings
Old Jan 15, 2008 | 05:52 PM
jrspringer06's Avatar
jrspringer06
Default Riser bushings
I am getting ready to start my ape hanger install. I have read that the stock bushings are a little to flexy for apes, any experience with this? The bike only has 1300 miles on it so it is not like they are old bushings. I was thinking about going to a poly bushing.
Old Jan 15, 2008 | 05:56 PM
DR.Greenthumb's Avatar
DR.Greenthumb
Default RE: Riser bushings
It's mandatory,you can do it now or do it later
Old Jan 15, 2008 | 06:00 PM
Big ACE's Avatar
Big ACE
you should do it now while everything is taken apart, easier that way.
Old Jan 15, 2008 | 09:27 PM
FXSTI Guy's Avatar
FXSTI Guy
With apes I'd definitely run the poly bushings...they'll take the "slop" out of yourrisers but you willfeel a little more vibration in the bars...I installed 'em with my Chubby 501 drags and have no regrets...you can get 'em cheap offa eBay.
Old Jan 15, 2008 | 10:27 PM
jrspringer06
Thanks that what I was thinking, and you guys just cleared it up for me.
Old Jan 16, 2008 | 10:45 AM
bensonjv's Avatar
bensonjv
I put 12.5" Wild1 Chubby apes on my Springer. Initially I just had the OEM bushings. Lots of slop and movement - which is what the bushings are deigned to do; absord vibration and provide some softness to the bars. But it was overkill, especially with apes. I put (Springer specific) poly bushings in and it tightened things up a lot. I can't say I noticed any added vibration. A local indy recommended I tighten them a little tighter than the spec torque. That helped firm things up even more.
If you are going to have the front end apart, I'd highly recommend you do the bushing swap. Its worth the extra couple bucks.
Old Jan 16, 2008 | 12:55 PM
SFarace20's Avatar
SFarace20
Change the bushings to the poly ones, it is pretty simple.
Old Jan 16, 2008 | 02:01 PM
jrspringer06
Benson, where did you find springer specific poly's?
Old Jan 16, 2008 | 02:14 PM
Pops28's Avatar
Pops28
you shoud put the poly bushings in anyway, even if you don't run apes.
The OEM bushings are so loose and if you ever remove or loosen them, and tighten them back up yourself, the bars are permanently "twisted" left.
Just switched mine out. Huge difference, cheap and easy!!
Old Jan 16, 2008 | 09:32 PM
Nails's Avatar
Nails
ORIGINAL: jrspringer06
http://dragspecialties.com/fatbook/15/440/3871750?q=art
