I'm using a 200/50-18, it's the closest circumference I could come to stock with the 18" rim, so the odometer and speedo would be accurate. The 50 series is pretty low profile. I've seen a 200/40-20 on a spoke wheel.......the sidewalls are almost nonexistent.
Are you guys running 18x5.5 rear wheels? I'm thinking about going to a 18 in the rear......all of the wheels I've seen say 17x6 (200 rear) or 18x5.5 (200 rear).
1badtrain,
if you can please keep a eye on the wear of your tire. i but one of there on my 07 custom and it wore very fast. i was under 1000 miles and the tire was allready cupping. right now the tire is shot at 2400 miles and the tread on eather side of the center of the tire is still in good shape. please let me know what it does for u thanks
1badtrain,
To have worn so quickly, maybe you have an alignment issue or another problem? Cupping is not a normal wear pattern......
