Am I wrong? (Engine Mod.)
Old Feb 13, 2008 | 09:09 AM
mike@nhca.us's Avatar
mike@nhca.us
Default Am I wrong? (Engine Mod.)
I have a 2007 Softail Custom.
I would like to get the Harley Stage 1 air filter kit and the SERT. I do not want to replace pipes or add slip-ons unless I have to.
I know the SERT is overkill, but I might want the 110 or other engine work in five or six years. I know it will take dyno-time.
It is my intent to free up the engine to breath correctly and get a better overall response and midrange power. I am not looking for peak HP, just long term reliable performance.
Will it work without the screaming eagle slip-ons? or do I need the exhaust more open as well as the input at this level?
Ps I have read the EFI post, know the slip-ons are street legal, and still just dont want to change pipes unless I really need to.
Thanks,
Mike@NHCA.US
Old Feb 13, 2008 | 09:29 AM
sportncruise's Avatar
sportncruise
Default RE: Am I wrong? (Engine Mod.)
I would say changing the pipe without changing the air filter is fine but the other way around isn't.
The stock air filter is pretty restrictive, if you give it more air and then more fuel you need to allow it to flow out correctly.
This doesn't always equal loud depending on baffle technology and style of pipes.
Old Feb 13, 2008 | 09:40 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
What your looking to do will work, just not as well as adding a less restrictive set of pipes/mufflers will.
If its the cost of them that's holding you back you can "fix" the stock mufflers so they areless restrictive, and have a better sound.
Check out the second half of this posting over in the Dyna section.
https://www.hdforums.com/m_2546488/m...tm.htm#2557186
Do the muffler "mod"with the SERT and AC upgrade and you shouldgetperformancesimilar to that of thenewer SEII's.
Old Feb 13, 2008 | 09:59 AM
PoorBoy's Avatar
PoorBoy
You're not really helping yourself out any until youenhance the WHOLE "air-pump", meaning youshould change the pipes too.
Different pipes doesn't automatically mean LOUDER. There are numerous baffle options out there that improve the motor's ability to breath better and keep the sound within "reasonable".
Old Feb 13, 2008 | 10:17 AM
sportncruise
ORIGINAL: PoorBoy
You said it so much better than I
Old Feb 13, 2008 | 10:21 AM
guild's Avatar
guild
Mike take a few minutes and read this.
http://www.thunderpress.net/MONTH_AR...headMemo.shtml
DanDolfn
Feb 14, 2012 10:41 PM
Yonaton
Feb 21, 2009 12:44 PM
Realeme99
Nov 20, 2007 01:27 PM
The Vig
Aug 2, 2007 03:23 PM
Dr Deluxe
Exhaust System Topics
Mar 21, 2006 04:00 AM
