2007 Custom Chrome tank on efi Fatboy
Old Feb 26, 2008 | 01:39 AM
deezel11's Avatar
deezel11
6th Gear
Default 2007 Custom Chrome tank on efi Fatboy
I have completed all th work required to get this tank finished only to find aftre it was all said and done that it does'nt have the fuel float bracket/ears to mount he fuel float on the right side of the tunnel. i ahve looked everywhere for a pressure bracket or something that will hold it in place. i don't see how the fuel gauge can work without it being mounted correctly in the tank. The description of the tank states that you can use your stock fuel gauge. Can anyone help please?????????????
Old Feb 26, 2008 | 06:51 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: 2007 Custom Chrome tank on efi Fatboy
I don't think the float assembly and sending unitis attached to the tank itself. If I'm reading my service manual right its attached to the top plate along with the fuel pump.
They are installed and removed as a single assembly.
Old Feb 26, 2008 | 08:40 AM
deezel11's Avatar
deezel11
6th Gear
The actual mounting tabs for the float are spot welded on the tunnel of the tank. The assembly comes out together but the actual assembly clips on the bracket.
Old Feb 26, 2008 | 09:47 AM
OK, Guess it must bea good day. I just learned something new. Thanks for that but sorry I can't help you out.
dta0251
Mar 25, 2023 07:10 PM
Fat11Lo
Aug 3, 2015 06:28 PM
fatboy1729
Jan 12, 2014 08:10 AM
ScReaMnEagLE22
Oct 2, 2009 09:14 PM
peterson24
Oct 15, 2007 04:25 PM
