LED array installed in Tombstone tail light
Old Mar 1, 2008 | 08:35 AM
Luxe's Avatar
Luxe
Default LED array installed in Tombstone tail light
Well I was sceptical when I ordered a LED array from Custom Choppers on ebay, as the price was muchlessthan everyone elses price.
Ebay
I had to remove the bulb socket assembly and use the die grinder on the grey plastic base to recess the array, so it was not tight against the lens. Then I drilled a screw hole into the grey plastic base through the hole provided in the array. Through this I used a small #4 screw to mount the array. I then used hot glue to brace the top of the array between the cover mounting towers. As for the wiring it is soldered & shrink tubed. I am very pleased with the instensity & pattern. I know there were others with Springer Classics & Deluxes that were looking into adding a LED array to brighten up the dim tombstone tail. This actually works pretty good for about $50.00.
Old Mar 1, 2008 | 09:46 AM
DrawDown's Avatar
DrawDown
Default RE: LED array installed in Tombstone tail light
That looks really nice!
Old Mar 1, 2008 | 12:34 PM
jokr's Avatar
jokr
YOU SHOULD HAVE WAITED ANOTHER MONTH OR SO KURYAKYN JUST MADE A PLUG & PLAY L.E.D.
FOR THE TOMBSTONE LIGHT I AM ORDERING MINE ONCE IT IS AVAILIBLE THEY SAID IT WILL BE READY THIS SPRING ALL YOU DO IS REMOVE YOUR LENS & BULB PLUG IN THEIR LENS $119.00
NOT BAD . ITS ON THEIR WEB SITE
Old Mar 1, 2008 | 12:46 PM
chromedome's Avatar
chromedome
ORIGINAL: jokr
I like Luxe's much better. Alittle more work with a lot of ingenuity and the price is right. As long as the conversion can be reversed and put back to stock. Just in case.
Old Mar 1, 2008 | 01:01 PM
Luxe's Avatar
Luxe
Yes it can be reversed with very little effort. The price of 119.00 for the Kuryakyn vs the 38.00 for the Rick Doss LED array..... well what can I say.
elfnyc
Jul 7, 2016 03:19 PM
senna
Aug 3, 2013 06:42 AM
Buckinfitch
Mar 21, 2011 11:56 AM
1.4G
Jun 7, 2009 08:09 AM
2007fxdc
Apr 1, 2008 08:39 PM
