Need a definite answer
Old Mar 2, 2008 | 08:40 PM
ecoli's Avatar
ecoli
Default Need a definite answer
Ok, can't find any clear cut answers to this question.
Is there fluid that needs to be drained before changing an OUTER primary cover?
Is there fluid that needs to be drained before changing the cam cover?
Thanks all.
Old Mar 2, 2008 | 08:49 PM
Rhubarb's Avatar
Rhubarb
Default RE: Need a definite answer
Cam cover no.
Primary cover, I assume you mean the round derby cover not the whole outer primary. If you stand the bike up you dont need to drain fluid for the round cover. If the whole outer primary, then yes you have fluid that will come out...
Old Mar 2, 2008 | 09:07 PM
ecoli's Avatar
ecoli
No, I'm replacing the entire outer primary cover. Is there a drain plug and a filler plug?
Old Mar 2, 2008 | 09:11 PM
ko4qc's Avatar
ko4qc
Make,Year and model would help but the answer is probably no...primary dosnt have a drain or fill plug...:&gt
Old Mar 2, 2008 | 09:12 PM
Abe_Lugo's Avatar
Abe_Lugo
The pre99 outer primary covers do, right under the larger derby cover. Should be an allen head bolt.
Old Mar 3, 2008 | 03:20 PM
ohiosofttail06's Avatar
ohiosofttail06
My 06 has that allen too, although it has the chrome engine kit, so maybe the original didn't. Fill through the inspection cover.
Old Mar 3, 2008 | 03:41 PM
Clammy's Avatar
Clammy
There's a drain plug in the stock primary on Reaper, and she's an '05 Night Train.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old Mar 3, 2008 | 03:42 PM
Mike NY's Avatar
Mike NY
So much for your clear and definite answer...
Mike
NY
Old Mar 3, 2008 | 04:12 PM
barjbar's Avatar
barjbar
The drain plug looks slightly larger than the other bolts on the primary cover. It's on the lower right side. When I replaced the bolts with the chrome hardware last year, I wasn't paying any attention and removed the bolt and the fluid leaked out. You don't replace that bolt.
Old Mar 3, 2008 | 04:24 PM
voyager1's Avatar
voyager1
This is why all need to buy a manual .
