HD quik detach windshield.....
Old Mar 19, 2008 | 06:42 AM
Korbenw7p3c's Avatar
Korbenw7p3c
Default HD quik detach windshield.....
does anyone else have any issues with the quick detach clamps leaving rub/wear marks on the forks? I asked the dealership if it were any problem when buying it, but they said it didn't leave any wear/rub marks. Mine is doing it and it's- making me mad.
Edit: what I really meant was HD Quick release windshield- clamp style. Opps.
Old Mar 19, 2008 | 06:54 AM
Strgzr's Avatar
Strgzr
Default RE: HD quik detach windshield.....
I have it. The plates that hold the windshield dont touch the forks. No wear marks. Rubber grommets can wear out a bit.
mike
Old Mar 19, 2008 | 06:55 AM
lionsqrne's Avatar
lionsqrne
Mine did on an FXST that I had. It wasn't rubber marks but the clamps had a protective tape on the inside of them. That eventually wore off and it was metal rubbing metal. I just used some heavy duty scotch tape and replaced the barrier. Problem solved.
After that though have to check them periodically to replace.
Old Mar 19, 2008 | 08:18 AM
Texas Fat Boy's Avatar
Texas Fat Boy
He's asking about the round FX front forks, not the FL bolt on ones.
Old Mar 19, 2008 | 09:37 AM
lionsqrne's Avatar
lionsqrne
If your reply was to be TFB I said it was on an FXST I once owned. If not to me... disregard.
If it's the detach with the C clamps... I know exactly what he is talking about.
Old Mar 19, 2008 | 10:01 PM
cwalms's Avatar
cwalms
I haven't had any problems with this on mine. However, I could see if the black composite inserts on the clamps popped out and you didn't notice that this could cause some scratching. My brother had his inserts pop out the last time he took off his windshield and told me to be careful of this when I remove mine. Just thought I would pass along the information.
Out of curiosity, has anyone else experienced this problem with their quick detachable windshield??
Lifestarts@40
Sportster Parts
Aug 19, 2016 01:10 PM
TNPorter48
Sportster Parts
May 27, 2016 10:34 AM
Berick
Mar 19, 2015 07:09 PM
black dyna
Feb 2, 2007 03:24 PM
