strutless heritage fender
Old Mar 20, 2008 | 02:02 PM
hoghead58's Avatar
hoghead58
Default strutless heritage fender
has anyone seen or done a stutless heritage fender
im going for the old hardtail look, any help appreciated
HH58
Old Mar 21, 2008 | 11:37 PM
Abe_Lugo's Avatar
Abe_Lugo
Default RE: strutless heritage fender
hi,
My suggestion is buy a heritage style wide fender that fits over the existing struts, run some spacer on the inside between the struts and the the inner fender,
or the other way is to mount the fender directly to the swingarm, like on the new Rocker model.
But you'll have to be running a spring solo or something that doesn't go far back enough to hit the rear fender. can be done. I should of though of these two solutions.
I'm wanting the heritage look, but added the wide tire on a pre 99 softail, I have a 160. so I ended up cuttiing the stock struts got a hot deal on some solid bolt on wide struts and will be running the wide heritage fender 9". but if your not running a wide tire I'm sure you can do the wide fender over the stock struts. Might look funny with a 130 tire though, did you ever see the New indians witht he wide skirted fender, sort of the same look.
doorsidedown
May 9, 2020 03:13 PM
roofer
Shovelhead
Apr 28, 2015 06:59 PM
csc06ss
Wheels/Tires
Sep 24, 2009 06:44 PM
Dawg Rider
Feb 17, 2009 08:18 AM
cajun883custom
Nov 28, 2006 03:00 AM
