Just installed a set of the Poly's with my Ape installation. They are much more solid and don't shift like the Rubber ones. Most people upgrade to them during a Riser/Handlebar swap.
I had a nice set of apes crack in half on me due to the original rubber bushings. They allowed flex in the risers no matter how much I tightened them down. This allowed the bars and risers to twist when I would steer. Eventually that torquing of the bars started to crack them. I replaced the whole thing with poly bushings, shorter risers, and of course new bars. Don't waste your time with the rubber ones.
I had the rubber for 1 week after my ape's were installed thinking I would get used to the play, but
I never did so I went with the poly. Hindsight is always 20/20
Iâm glad I ask.
If the vibration with poly bushing is not an issue,
then Iâll be making the switch when I have my new 3â risers installed.
Thanks
I am still running the rubber bushings b/c I did not know about the poly ones at time of installing my 12.5" apes. I don't really have an issue with movement or anything so I have left them alone, however, I will swap to poly's at some point. Thinking of going to 16's at some point, so I would definately change before doing that.
