Front axle question, 2007 FXST
Old Mar 26, 2008 | 09:40 PM
Thor's Avatar
Thor
Default Front axle question, 2007 FXST
I'm looking hard at getting this wheel: https://www.hdforums.com/m_3048917/tm.htm and reads "t will bolt right up to front stock FXST wide glide or Deuce with 3/4" axle, using stock spacers/rotor.", but the seller did warn me to "check for your front inner diameter bearing size. This wheel has 3/4" ID, and i read that 07+ has 1" or 25mm? i am not sure if you can just swap the bearings, maybe some fellow member can help "
I'm trying to read up on it in my Shop manual, but I dont know if I'm lookin at the right stuff.....so, can any fellow members help? I would be most appreciative....the fat fronted stripped model (aka Standard) with pegs (not boards) was the picture I've had in my head for awhile now....
Old Mar 27, 2008 | 03:30 AM
story808's Avatar
story808
Default RE: Front axle question, 2007 FXST
here this may help...
https://www.hdforums.com/m_3101111/tm.htm
Old Mar 27, 2008 | 04:39 AM
mojojones's Avatar
mojojones
The '06 and '07 bearings have the same outer diamater but the '06 bearing is thicker.
scooper321
Wheels/Tires
Feb 23, 2018 06:03 PM
abez
Wheels/Tires
Oct 31, 2016 03:15 PM
danicol12
Wheels/Tires
Jul 23, 2014 01:55 PM
Good_Apollo
Feb 10, 2014 09:46 AM
MNbiker59
Aug 14, 2010 04:53 AM
