Valve Stem Loosing Air
Old Feb 22, 2006 | 10:17 AM
06ClassicSpringer's Avatar
06ClassicSpringer
6th Gear
Default Valve Stem Loosing Air
My brand new 06 Classic Springer rear wheel valve stem is loosing air and the tire is basicaly flat. Im totally bummed......i thing its a warrenty issue and will call the dealer later today.
Anyone experience the same thing?
Old Feb 22, 2006 | 10:53 AM
HDF Tech's Avatar
HDF Tech
Default RE: Valve Stem Loosing Air
Get yourself one of those valve core removers at any auto supply store or the cap they use on a bicycle tire valve with the split top on it. The stem could just be loose.
Old Feb 22, 2006 | 06:47 PM
AF Scootertrash's Avatar
AF Scootertrash
06 Springer-
TC is right on as usual. I worked in a chain tire store when I was in high school and I can't tell you how common of a problem this is. We used valve stem removers that were the size of a small screwdriver or you can get the simple valve stem cap kind that TC suggested. Either way get it, use it, and add it to your tool kit for the road.
Old Feb 22, 2006 | 08:03 PM
06ClassicSpringer
6th Gear
Its not that....the air is escaping from the sides of the valve stem...close to the rim. Anyway, i had the dealer come pick the bike up, let them figure it out. its to new for me to be messing with it anyway.
Petiej
Apr 25, 2019 07:03 AM
heng
Sep 18, 2011 08:27 AM
offshoreo
Apr 24, 2010 01:00 PM
Lincoln33
Nov 5, 2009 01:05 AM
flynavy
Mar 24, 2008 07:21 PM
