Breaking in a Springer
Old Feb 23, 2006 | 09:05 PM
ckamin's Avatar
ckamin
Default Breaking in a Springer
Although I've done everything by the book on all of my bikes, a co-worker said that he changed the oil at both 50 miles, then 500 miles, prior to its 1000 mile service on his Yamaha FJR1300. Is there any rational need for this (other than peace of mind)? Being a Springer, my bike goes in at 500 miles for it's first service. After tomorrow, it'll have 200 miles on it. Any reason to change the oil now, since it will be completely serviced at 500?
Also, is there a drainage tray for Softtail oil filter removal that anyone makes?
Thanks!
-Carl
Old Feb 23, 2006 | 09:12 PM
SPRINGER's Avatar
SPRINGER
Default RE: Breaking in a Springer
Howdy Carl. I am not an authority on Harleys or mechanics, but when I bought my Springer last year, I just followed what my manual said. So far, no problems doing that.
Old Feb 23, 2006 | 11:19 PM
evo springer's Avatar
evo springer
no reason to change the oil that many times unless you like wasting money, especially if you are using harleys syn3 (one fluid for everything) like i am at almost ten bucks a quart it won't be cheap oh and on the drainage thing i believe jp cycles carries one if not search the web they do exist i've seen them good luck hope this helps
Old Feb 24, 2006 | 10:43 AM
went_postal's Avatar
went_postal
Odds are your friend changed the oil like that because there is a common thought that early in the break-in process you are knocking some metal off of the cylinder...
On my cars... I will typically remove the craptastic oil that it comes with brand new. On the Harley I just let the dealer tell me when to deal with the maint. on the bike. When I bought mine I got the first three years of service with the bike. If I recall, I had the dino-oil done at 500 and at 1500 ( I could be remembering this wrong). and I also had another change to syn3 at 2500. I believe my next change is at 5000 (at 3800 right now).
It was just suggested to me to stick with the "normal" oil for the first two changes. On Syn3 now.
Old Feb 24, 2006 | 11:00 AM
HDF Tech's Avatar
HDF Tech
Most important oil change you can do is the first one in the life of the engine. You'll find there is a lot of "slag" inside a motor casting and in the oiling system and it's best for you to get that out after a few break in miles. It amounts to a few dollars to do this but so is the cost of the bike or a new engine.
I did mine ant 100/1000/2500 complete with a filter and synthetic oil and have followed this on every motor I have owned with good service life and no problems with oil consumption.
I've never found a way of changing oil in these bikes without making a mess. Just clean the bike after you change the oil and it takes less preperation than trying to catch all the oil which you will not succeed in doing.
You may find this topic interesting for your oil change... https://www.hdforums.com/m_254963/mp.../tm.htm#254963
Mike
I really do not classify this as a waste of money any way you look at it , especially if you plan on keeping the bike for any length of time.
PLEASE do not use the Syn 3 in your transmission as you infer here. Use a GEAR oil in the trans like Mobil 1 75/90 or Redline shockproof heavy, but NOT an engine oil. Problems with the transmissions running Syn 3 are starting to show up and you'll find that HD does not advise the Syn 3 to be used in the trans in the 06 bikes any longer.
Furthermore, you'll find that Syn 3 is not a full synthetic regardless of what they try to tell you. The other brands like Mobil 1 and some others are a full synthetic oil that is not formulated starting with a dino oil. Food for thought.
Old Feb 24, 2006 | 12:13 PM
evo springer
i just thought the 50 mile mark was a bit much, now ya got me thinkin about the trans fluid i also thought it seemed a bit thin to be going in the tranny but they assured me it was ok maybe i'll change it when i change all the oil this spring if that ever gets here
Old Feb 24, 2006 | 12:15 PM
evo springer
ok while we are on the oil subject what kind of filter do you use
Old Feb 24, 2006 | 12:53 PM
HDF Tech's Avatar
HDF Tech
ORIGINAL: evo springer
I only use the HD brand. They are specked for the engines and built by a manufacturer to those specs. There are a few factors to be considered in filters such as filter media size, bypass spring tension (not all the same here) type of end caps (cardboard) and method of attachment plus more than meets the eye for most.
You'll find some interesting posts here in the oil section of the DIY that may prove helpful in answering some questions you might have, take a look in particular into the "oil filter comparisons" 7 up from the bottom of the page.
https://www.hdforums.com/forumid_249/tt.htm
I try to be somewhat impartial and base my decisions on what I have found that works well and not to be biased by dealer talk (hype) and price savings between chosing brand X and the name brand. I probably waste more money on items than most by over servicing things, but I feel strongly about keeping quality parts and the best oil that I think will give me the results I want regardless of the cost. My bike is a bit higher in price than some and I really can't justify trying to save $3 on an oil filter at this point. JMHO
Old Feb 24, 2006 | 02:10 PM
Unibomber's Avatar
Unibomber
Just turned 600 on my new Springer and I just ordered my Amsoil and have already received my scavenger, ill be doing my oil change as soon as my oil arrives.
Old Feb 24, 2006 | 03:23 PM
LouieWideGlide's Avatar
LouieWideGlide
Harley and JP Cycles have the tray for oil changes. You usually make a mess anyway, but they look like they work. Sorry, I don't have the part numbers.
