New HogPro Front Wheel mounted
Old May 22, 2008 | 07:18 AM
aviscomi's Avatar
aviscomi
Default New HogPro Front Wheel mounted
Well I mounted my new HogPro Primitive front wheel last night; now I'm debating whether or not to replace the rear...
[IMG]local://upfiles/36332/6B45F8F3B3C5406FA0411791A346CD11.jpg[/IMG]
Old May 22, 2008 | 07:39 AM
tlb's Avatar
tlb
Default RE: New HogPro Front Wheel mounted
the wheel looks good. I like matching wheels front and back, or a solid on the back and custom on the front. I would think about doing the forks and removing the reflectors.
Old May 22, 2008 | 07:41 AM
Redstripe's Avatar
Redstripe
Looks nice. I don't know if I would bother changing the rear. The disc brake covers almost the entirety of the rim. Maybe put it on a low priority upgrade list.
Old May 22, 2008 | 07:47 AM
Sarge4life's Avatar
Sarge4life
ORIGINAL: Redstripe
Ditto.
Old May 22, 2008 | 07:53 AM
aviscomi's Avatar
aviscomi
After looking at the pic for a few minutes I realized that "shelling out" another $1,000+ for the rear wheel would be a waste; especially since the rotor & pully cover most of it. BTW what's the best way to remove the front fork reflectors...fishing line?
Old May 22, 2008 | 08:30 AM
Sarge4life's Avatar
Sarge4life
I just pulled mine off with my fingers. There is a layer of white foam with adhesive under it that gets left behind, but you can use Goo Gone and somemanual laborto remove it. I've heard that a heat gun works, but I don't have one.
Old May 22, 2008 | 08:49 AM
DrawDown's Avatar
DrawDown
ORIGINAL: aviscomi
Thats why you get it with a matching pulley and rotor. Just my opinion, but i like matching wheels. Front looks good though
Old May 22, 2008 | 09:20 AM
jtmurph00's Avatar
jtmurph00
Ditto, on doing the matching pulley and rotor it really opens up the rear end and looks great. But, it is alot more money.
Fishin line works great for removing the reflectors, make sure the bike is parked outside and in the sun though, they need to be warm.
Old May 22, 2008 | 09:30 AM
aviscomi's Avatar
aviscomi
ORIGINAL: jtmurph00
Is your back wheel/rim the same as the front or did you just change the rotor & pulley to match the front. BTW, I did get the matching rotor for the front (not seen in pic).
Edit: NVM, I just noticed that you have the stock rotor...
Old May 22, 2008 | 09:32 AM
Pork-Chop's Avatar
Pork-Chop
if you are gonna do it....do it right, I think you need to do the rear, it looks incomplete to me JMO
