Rocker C total redo
Old May 27, 2008 | 06:39 PM
skipdogg01's Avatar
skipdogg01
Default RE: Rocker C total redo
Looks great did you change out the handle bars? If so what brand and style did you go with? Im having a hard time finding someone who has done the bars on the Rocker C.
Old May 27, 2008 | 07:09 PM
orthodoc's Avatar
orthodoc
Wow, you guys posed a lot of questions!
How did you handle front fender mounting with the 21" tire.
New front fender
Which rim did you use for the front?
Can't quote the rim right now, but I will in a 2 weeks
Did you consider taller fork tubes?
They are longer by 1.25 inches
How easy was it to install the Aircleaner?
Real easy, I had the custom shop do it when I had the 103 cubic inch motor upgrade.
You need a PA-C in your Ortho Practice?
PA working right now, but...
The fork were changed since the original bars don't fit anything else so...
Old May 28, 2008 | 11:50 AM
orthodoc's Avatar
orthodoc
Well the air ride is finally installed. What a pain! Because of the V&H pipes and air ride need to share the same two bolts on the right side of the bike. Well...more custom stuff! Pic coming.
Old May 28, 2008 | 12:50 PM
wkenddad's Avatar
wkenddad
Where did you get the fork tubes?
I've talked to several vendors and they were not sure if the 49mm tubes they had in stock would fit the Rocker.
They said info from HD has been slow in coming and that is why a lot of aftermarket stuff is not out there....
Old May 28, 2008 | 11:24 PM
gadawgsfan's Avatar
gadawgsfan
orthodoc, first, your scoot looks great, may i ask what air ride system did you go with, i cant find one that will work, i do have mine lowered but the ride is not all that great so my next step is air ride and because of the hump in the transmission the ones i have seen would not work. if you could tell us the brand and part number i would be very thankful
thanks in advance
Old May 29, 2008 | 12:13 PM
orthodoc's Avatar
orthodoc
I will post pictures and part # for the air ride and fork tubes tonight
Old May 29, 2008 | 11:32 PM
orthodoc's Avatar
orthodoc
Update on the bike with pics. Check out Rocker C project. Let me know what you think.
Old May 30, 2008 | 04:41 PM
orthodoc's Avatar
orthodoc
The air ride is from SAS
Old May 30, 2008 | 07:08 PM
m i k e's Avatar
m i k e
with all that bling you must have another scoot
oh the torture it must be......
Old May 30, 2008 | 11:11 PM
renoa18's Avatar
renoa18
Looks awesome
