Rocker C total redo
Old May 25, 2008 | 02:01 AM
orthodoc's Avatar
orthodoc
Default Rocker C total redo
Well as promised, here is a couple of pictures of my rocker under construction. I know that some of the pics are blurry...sorry! I am hoping the change will be radically good. Here you see the forks have been changed, new 21 inch front wheel and tire plus new bars. Matching rear wheel, air ride, chrome inner primary, new lights, seat, forward controls and finishing parts will be installed as well. Then off to the paint shop. I can't wait to get it done. Let me know what you think! I am going to keep the blue, but new flames or something else you recommend will be applied. Thanks
Old May 25, 2008 | 04:48 AM
Iccer's Avatar
Iccer
Default RE: Rocker C total redo
WOW what a project for that beast you got there, cant wait to see it get together, look forward to seeing the forward controls and how it feels.
Thanks for sharing.
Old May 25, 2008 | 07:39 AM
Jerry L's Avatar
Jerry L
Man, you've got yourself a cool project there! Front end and wheels look great! Keep us informed with more progress pics.
Jerry
Old May 25, 2008 | 08:17 AM
m i k e's Avatar
m i k e
[sm=bling.gif]
Old May 25, 2008 | 11:20 AM
orthodoc's Avatar
orthodoc
Thank you. I will post more pics this week. The project should be done by the 4th of June.
Old May 27, 2008 | 01:05 AM
orthodoc's Avatar
orthodoc
The air cleaner is a D&M Twister Air Cleaner
Old May 27, 2008 | 07:45 AM
m i k e's Avatar
m i k e
sweet a cleaner i dropped $ on them as well
Old May 27, 2008 | 08:19 AM
rjmac53's Avatar
rjmac53
keep us posted...
Old May 27, 2008 | 12:59 PM
MartyF's Avatar
MartyF
Great project! Thanks for sharing. Looking forward to see how it turns out.
Old May 27, 2008 | 01:25 PM
wkenddad's Avatar
wkenddad
Questions:
[ol][*]How did you handle front fender mounting with the 21" tire.[*]Which rim did you use for the front?[*]Did you consider taller fork tubes?[*]How easy was it to install the Aircleaner?[*]You need a PA-C in your Ortho Practice?[/ol]
I'm getting mine next month and considered doing the following:[*]21" front wheel (Slasher) with matching rotor.[*]Raising the front Fender 1"[*]18" Slasher rear wheel with matching pulley[*]Extending the fork tubes 2-4"[*]Raising the tank 2" front and 3/4" rear[*]V&H 2 into 2 pipes[*]Moving turn signals to fork tubes[*]Similar Air Cleaner[*]Clean up the rear fender
[ul][/ul]
Always knew I should have gone into Ortho......
