Primary level?
Old May 26, 2008 | 04:27 AM
SlowRide1010's Avatar
SlowRide1010
Stage I
Default Primary level?
I don't have any manuals for my bike. I know I need to get them just haven't had time yet. I have a 98 Heritage that my father left me when he passed. It took me awhile before I was ready to ride it.
Myproblem is I replaced the inspection plate gasket but don't know how to check the fluid level in the primary. I am used to the way they set the V-rods up where there was only one oil level to worry about. Does the primary share the tranny oil or is it seperate? If seperate how do you check it? I haven't spent much time trying to figure it all out yet just noticed it leaked so I fixed it but now I'm not sure if its low.
I know they are dumb questions but I thought someone would be willing to help. I have never owned a "Real" Harley before...
Old May 26, 2008 | 05:38 AM
Vikingnomad's Avatar
Vikingnomad
Default RE: Primary level?
Best bet would be to pull the drain plug, allow all the oil to drainand once empty re-install the plug and add a quart of good 20-50 oil to the primary....and no the tranny and primary don't share oil.
Bone
Old May 26, 2008 | 07:29 AM
Nitram_b4's Avatar
Nitram_b4
Tranny oil and Primeary oil are sep. and I would do as stated before drain it and it will take a quart of 20/50
Old May 26, 2008 | 07:34 AM
tnharley7's Avatar
tnharley7
Put the bike vertical and not on the kickstand. Remove the derby cover. Use a flashlight and look down into the primary. The oil level should just be "kissing" the bottom of the clutch diagraphm (looks like a shiny brake rotor). If it is full enough, wipe off the gasket and derby cover with a clean towel and re-install. Torque the bolts to 84-108 in-lbs in a star pattern. You should be ready to go.
jasonjazz317
Apr 3, 2025 06:24 PM
Jake Borges
Jul 14, 2018 01:18 PM
skyhawk940
May 6, 2014 01:49 PM
OldTyme
Aug 11, 2013 05:46 PM
Gpsjr10
Oil Archive (no new posts)
Jun 23, 2007 08:23 PM
