ADDING 3 IN RISER
Old May 26, 2008 | 08:40 PM
WERE TO's Avatar
WERE TO
Stage I
Default ADDING 3 IN RISER
I HAVE A 07 FLSTC LOOKING TO INSTALL 3 IN RISERS. I LIKE TO KNOW WHAT CABLES AND SWITCH WIRING NEEDS TO BE CHANGE AND WERE I CAN BUY THEM THANKS FOR THE HELP
Old May 26, 2008 | 09:15 PM
05 DELUXE's Avatar
05 DELUXE
Default RE: ADDING 3 IN RISER
might not have to change anything. depends on the bars also..are u changing them? if so u have to allow for the extra height. eg.. i instyalled 16 inch bars with 1 1/2" risers and went 6 inches over stock on all cables.
Old May 26, 2008 | 10:19 PM
keno's Avatar
keno
I just installed a set of Pullback Risers - 1 1/2" inch set back - 4" inch rise. I didn't change the handlebars and was able to use the stock cables after slight adjustments to them, BUT if I wanted to push the bars as high as they will go I would need a couple inches on cables.
rrambo
May 22, 2011 11:32 PM
Smitty79
Nov 4, 2010 11:14 AM
j88j
Oct 19, 2010 06:28 PM
DynaRyda06
Jul 18, 2010 10:36 PM
mfgarcia68
May 26, 2009 12:01 PM
