Removing reflectors
Old Jun 4, 2008 | 12:28 PM
panamoncreel's Avatar
panamoncreel
Default RE: Removing reflectors
+1 on hairdryer. Heat it up really good and the glue loses it's tack. Then use Goo Gone or something like that to rub the remaining goop off. Piece o' cake.
Old Jun 4, 2008 | 12:35 PM
n928kc's Avatar
n928kc
what a Coincidence i took mine off my 2008 crossbones yesterday. They twisted off & i used a release agent on the remaining double faced tape. 5 minutes a side...
Old Jun 4, 2008 | 02:04 PM
ronyd's Avatar
ronyd
+2 on hairdryer or heat gun. Pryed off with small bladed screwdriver, followed with heat. should come right off. Also heat is definitely good if taking off the protective cover on rear fender.... Should have to use any solvent...
Old Jun 7, 2008 | 05:33 AM
Vikingnomad's Avatar
Vikingnomad
Plastic putty knife to pry the suckers off and Goof Off to get the remaining glue off
Bone
Old Jun 7, 2008 | 08:34 AM
Texas Fat Boy's Avatar
Texas Fat Boy
On my Fat Boy I heated mine up with a Hair Dryer and just pulled them off
then used Goo Gone to remove the remaining glue.
&nbsp\\;
I bought the Goo Gone in the paint section at Walmart.
I've used WD-40 in the past but Goo Gone is better.
Old Jun 7, 2008 | 04:09 PM
6165hd's Avatar
6165hd
Take your bike for a ride, get it heated up, or let the bike sit in the sun, and the metal gets hot, those plastic suckers come right off...... and w/&nbsp\\;w-d 40 as mentioned takes the glue off, with a little rubbing with a soft cloth,&nbsp\\;easy!!!!
Old Jun 7, 2008 | 10:08 PM
azfathog17's Avatar
azfathog17
The dealer removed my rear reflectors when they installed the backrest.&nbsp\\; They did not need to come off but that is different story.&nbsp\\; I used goo gone to remove the residual adhesive from the the aircleaner cover warning sticker.
Old Jun 8, 2008 | 07:37 AM
Archer1968's Avatar
Archer1968
I did the same as texas Fat did. i called it Debadging....lol
Casper
66
Oct 19, 2019 11:44 PM
Chris Creole
Jun 17, 2014 10:29 PM
erwindaveo
Jul 16, 2012 09:42 PM
streetbob09
Dec 23, 2009 10:01 AM
ny06fxdb
Apr 29, 2007 11:00 PM
