Rocker stage 1
Old Jun 10, 2008 | 01:51 PM
jwest1975's Avatar
jwest1975
5th Gear
Default Rocker stage 1
I have Vance and Hines Big Radius pipes on the way along with Big City Thunder baffles and a SE Heavy Breather intake.My question is if everyone is going with a tune or fuelpak on this setup?I have been told by a couple of different people that on the 2008's with O2 sensors, that it is possible to not need either option. I was advised that I could try and run it without and see if I have problems with popping and hiccuping and if problems arrise, then add the tune or fuelpak.Can anyharm be done by trying this?Is anyone running a similar setup with sucess?What are your thoughts?Thanks!
Old Jun 10, 2008 | 06:55 PM
Other Sheep's Avatar
Other Sheep
Default RE: Rocker stage 1
I used a fuel pak with my heritage with V&amp\\;H pipes and K&amp\\;N filter set up. It worked well but when the XiED from nightrider.com came out I bought and installed a set and they helped cool the bike dramatically. Fuel pak works during open loop for the 07, 08 bikes which is 50% to full throttle. The XiED or IED works during closed loop which is from idle to 50% throttle.&nbsp\\;No more high heat at stoplights.
Old Jun 11, 2008 | 10:26 AM
RockerMike's Avatar
RockerMike
I don't believe that is true. I went with the SERT. People go back and forth with their opinion and I'm sure they are all great in their own way, but my dealer was more comfortable with the SERT so I went with their recommendation.
Old Jun 11, 2008 | 12:30 PM
reds2harleys's Avatar
reds2harleys
I put Big Radius pipes on my Rocker along with the 103in stage 2 kit and the bike runs great.&nbsp\\; I had HD do their download for the 103 kit and then put the pipes on myself and have had no problems.&nbsp\\; I just cut the baffles in 1/2 and the bike sounds awesome.&nbsp\\; Good luck
Old Jun 11, 2008 | 01:39 PM
airheads's Avatar
airheads
Former Sponsor
I have also heard that the '08's ECM are able to self adjust, but I don't know how much they can adapt or if this is even true.
&nbsp\\;
Does anyone have the definitive answer to this?&nbsp\\; I'm sure that if it can adapt, the aftermarket suppliers wouldn't be too happy.
&nbsp\\;
I've done a lot of reading on ECM's and think I am leaning toward the Thundermax.&nbsp\\; It has the ability to adjust to&nbsp\\;whatever setup you have (pipes, AC, cams, etc) plus it can adjust for whatever riding conditions (temperature, elevation etc) you have.&nbsp\\; It costs a lot more than the others (SERT, fuelpac, PCIII etc.)&nbsp\\; but does not need dyno tuning no matter how many times you change your setup.&nbsp\\; Change your&nbsp\\;setup more than once and it pays for itself.&nbsp\\;
Old Jun 12, 2008 | 01:03 PM
keithab's Avatar
keithab
I have close to the same setup and went with the Power Commander III. Just had a new map put on it and it runs great.
&nbsp\\;
Keith
Old Jun 12, 2008 | 01:19 PM
ChosenDFW's Avatar
ChosenDFW
Keith, I got a shop in Kileen TX ready to install the PCIII into a Rocker C - a first for them!!
Old Jun 12, 2008 | 06:44 PM
jason628's Avatar
jason628
Greetings,
&nbsp\\;
My stealer told me the same thing about the ECM. I went about 200 miles on new pipes and the air cleaner kit only to be about cooked on the seat from the heat, along with it running sluggish. So today I had the Stage 1 download done and the bike has more power, runs cooler, starts easier, and just plain sounds better. Definitely do at least the download from the stealer if not the Thundermax.
Old Jun 12, 2008 | 07:03 PM
Other Sheep
In stock for the bike has an air/fuel ratio of 14.7 to 1. Tuner should take it closer to 13.8 to 1. Do a search, theres lots of info here.
kipd
Aug 16, 2009 10:35 PM
cornholio
Dec 1, 2008 09:59 AM
Soldierz
Aug 10, 2008 10:13 AM
BLACKROCKERC
Apr 23, 2008 09:26 AM
scorp58
Jun 15, 2007 03:32 PM
