fuel management needed for aftermarket pipes?
And if you do change the intake, just get the Stage 1 download. I have changed my intake and running Vance and Hines Shortshot Staggereds on mine. All I have is the Stage 1 download and no issues whatsoever. A lot cheaper than the race tuner!
Same thing no problems.
federal Government. (EPA) They are not picking on the MOCO as every motorcycle manufacturer comes under the same general law. The bikes that are water cooled are having an easier time of complying because they generally run cooler. A water cooled engine generally runs considerably cooler than an air cooled variety.
Now, just because they run lean from the factory does not mean that they will burn a hole in the piston when you cruise at 70 mph. I have yet to hear of that happening unless someone was using a fuel delivery device and mistakenly had it set so it subtracts fuel from the factory map. Some of the fuel injection devices are not capable of subtracting fuel, but they do add fuel when it is called for by sensing things like air volume, rpm and demand. Unless you are in a racing environment, my opinion has always been that most of these devices are overkill, to say the least. I would think the vast majority of owners (95%) who run their bikes on the street or at highway speeds would be much better suited by installing one of the devices that adds fuel when it is needed rather than having the capability to both add and subtract fuel. Devices such as Harleys Race Tuner is pretty expensive to say the least and it does have the ability to subtract or add fuel. If installed, whether by the dealer or individual, it pretty much voids any factory warranty which may or may not be in effect. A device such as the Dobeck TFI is only capable of adding fuel when it is called for so there is never a risk of burning a hole in a piston because it will never run any leaner than the factory installed map whether it is the stock version or the SE Stage 1 download. If a dealer wanted to be chicken enough they could even claim a TFI could void the warranty but I have not seen that happen.
I don't own any such devices for myself but I have helped a lot of friends install them on their bikes. Any yes, when you install new slip on mufflers, download the Stage 1 download from the factory and put on a SE Stage 1 air cleaner you will increase the performance of your motorcycle. And once again, if you install a fuel device of which there are many available, that will increase your performace even more. Remember some devices only add fuel when demanded and some subtract fuel as well as adding fuel. Everyone has to decide which is for them. Generally speaking the devices which both subtract fuel and add fuel are more expensive. In addition those type devices are best tuned by using 2-4 hours of very expensive dyno time or at the very least having a laptop computer to set up a new map. The types that just add fuel are pretty much just plug in and go. The base (uninstalled) price of slip on mufflers will generally run $300-$800.00. The Screaming Eagle air cleaner is about $130.00. The SE 1 download from the Harley dealer is another $150.00.
Anybody have comments? Lets hear them.
