installing bars and cables
Old Jun 14, 2008 | 02:40 AM
brianp25's Avatar
brianp25
Default installing bars and cables
got my new bars and cables any tips and lil tricks on the internal wiring and the cables? i know its been covered and ive used the search, just want to make sure i get all the tips, from what ive read its a pain. ill also be switching all the fluids over to amsoil at this time.
Old Jun 14, 2008 | 08:52 AM
lanceo70's Avatar
lanceo70
Default RE: installing bars and cables
It is kind of a pain the first time. I internally wired my 16" apes. I ran a peice of thin wire from the bottom ( I used welding wire ) and&nbsp\\; made a small hook on the end and used electrical tape to tape the wires to the wire. I squirted some penetrating oil in my handlebars to help the wires around the bends...seemed to help but still took some tuggin and pulling. Anyway thats how I did it.
Old Jun 14, 2008 | 03:02 PM
tlb's Avatar
tlb
i just pushed the wires through the bars and it was easy but if they had ahard turn a wire or string would be easier. take off the tank first dont screw with sliding it back. when u remove the tank. if your bike is efi, first thing you do is pop off the fuel line. PM if you want to call and talk to someone before you start
&nbsp\\;
Old Jun 14, 2008 | 06:03 PM
gunner065's Avatar
gunner065
I got rid of the stock protective covering over the wires and replaced it with shrink rap. A little silicone and it slid through slicker than snot on a chickens lip.
Old Jun 14, 2008 | 08:41 PM
Loser1's Avatar
Loser1
I disconnected the wires from the connectors (took digital pics first to help replace the connectors), taped up the ends with electrical tape and in about 5 seconds a side the bars were wired.
&nbsp\\;
At first I made it real complicated but it nded up easier than what I thought.
&nbsp\\;
L1
Old Jun 15, 2008 | 12:14 AM
brianp25's Avatar
brianp25
update i got the wires ran and the bars on, tomaorow all i got to do is change the cables and fluids, went alot easier then i thought.
Old Jun 15, 2008 | 06:56 AM
TheGeek's Avatar
TheGeek
You can use weed wacker string for a fish tape and not worry about scratches.
103RATRIDE
Mar 4, 2013 09:45 PM
jeh83
Mar 23, 2011 01:53 PM
firemedic58
Jan 7, 2009 12:30 AM
drogers
Jun 1, 2008 06:26 AM
roofer
EVO
Apr 9, 2008 01:47 PM
