Rear turn signal relocation?
Old Mar 5, 2006 | 12:31 AM
Dr. Fatboy's Avatar
Dr. Fatboy
Default Rear turn signal relocation?
I just finished installing the Softail Leather Saddlebags (fatboy styling 90320-00C) with Barebacks detachable mounting system. I have a 2004 Fatboy. The rear bullet style turn signal is rubbing against the leather saddlebag and it is a very snug fit to slide the rear of the saddlebag cover between the mount and the turn signal. The turn signal relocation kit has already been installed. If I were to move the turn signals in closer to the fender struts, this would take care of this problem. There is a spacer on each side 1 1/2 inches in length which puts the turn signal this far out from the fender. Has anyone else encountered this problem? Is there a way to get rid of this spacer and move the lights in? Any other options or opinions would be appreciated.
Old Mar 5, 2006 | 12:41 AM
SHEP's Avatar
SHEP
Default RE: Rear turn signal relocation?
You can use a shorter spacer. Look at a CC or Drag catalog. I've done this many times.
Zeteo
Feb 19, 2013 04:31 PM
KnightWRX
Nov 10, 2009 06:57 PM
smitbrad
May 24, 2009 04:01 PM
eddie57
Apr 15, 2009 10:10 AM
budiii3
May 15, 2007 01:20 AM
