Does the fuelpak raise the revlimiter? If not is there a way to disconnect it or raise it without a remap from the dealer? Haven't bought the Fuelpak yet, I'm just looking at all the options before spending the money.
My bike is a 2007 Softail Standard with V&\\;\\\\\\;H Big Radius pipes. I have a SE Stage 1 air cleaner that I haven't installed yet. I've also ordered the Xied's.
Any help will be appreciated.
Go to WWW.vanceandhines.com They have a fuelpak section you can go to. There you can get all your questions answered. If its not there, you can email them, they are pretty quick with the reply.
No, it doesnt change the rev limiter but unless you do some engine work, cams, bigger bore etc, youre not gaining anything by reving higher. The power drops off too much above 5500 rpm.
