Probably been asked a million times but I cant get the search thing to work......
Do you need to adjust any electronic mapping etc etc if you are fitting a Big sucker air filter and slip on pipes ? Fat Bob is the bike and don't want to change the header pipes just want it to breathe better run smoother and sound better.
Oh forgot to mention I fitted the Xied's today but not run her yet.
Thanks for the patience !!
If you change the intake (increase) \\;you should get a stage 1 download, at least, even with the Xied's because the Xied's are not going to affect your AFR at WOT.
I've heard the dealer installed download is a wast of $$$$$$$$.
I'm running a Fule Pack. After installing the AC, pipes and fule manager I changed to the quiet baffels &\\; was able to change the AF ratio setting in my own garage, in 5 minuets and for free!
wont the stock computer adjust the fuel automatically if you change air intake// the one on my grand national always did
It's not a Buick, it's a Harley - haha. \\;
Since you have the IED's, you may only need a stage 1 download but you need at least that at a minimum. \\; I've seen people report good results with that combination. \\; Bottom line, you need to do something more because of the high flow a/c than the pipes/mufflers. \\; There are many other options of course, i.e. fuelpak, T-Max, SERT, PCIII, etc. \\; But yes you need something more than what you have.
Ok Guys
I'm not to shabby with wrench and driver but when it comes to electronics I'm as thick as proverbial so.....
Am coming to America to visit bike shops { ok and Disney } What should I buy and can I do this download thing myself ? { Remember thick as ... with techno } .
I am going to look at the rush slip ons and considered the Ness big sucker filter .
What gizzmo do I need - best bang for $$$$$$
What ever happened to good old carbs ...........
If you buy a matched set of intake and exhaust its the only way to know if you have to re-map and what level you, otherwise you need to Dyno it.
I bought the S&\\;S low restriction intake and slip-on pipes which the stock ECM can adjust for to keep the same air/fuel ratio and emissions as stock.
