I know this is probably a post that should go in the tech section but the rocker guys seem to be most active on this forum.
Can the PCIIIusb be installed on a rocker? I don't get mine until the fall but I'm trying to order everything up so when it drops I can have everything ready to go. If the PC isn't compatible I will have to look at other options.
Some said that the PCIII would not fit on the Rocker\\\\\\; however, I know that at least one person got it to work. I can find the link but it was posted on this board.
The dealer used the SERT on mine. Its nice because it doesn't stay on the bike.
Sorry for the delay Ive been trying to reply to this since last week \\;[:@]
 \\;not \\;long ago I contacted Dynojet about the PCIII usb on a Rocker and this is what I got back from them: Since we do not endorse the power commander iii on this model we do not have any maps. It would be best to either try the standard Softail maps or bring the bike to an authorized tuning center to have a map developed for you. Thanks.
Dustin Schaller
Technical Support Manager
Dynojet Research
800-992-4993
I also called the guys at Fuel Moto, they said they had not found a place to put the controller on a Rocker, but that they had done a few cross bones and that the maps should be close (at least a good starting point).
Then I foind this guy on youtube: www.youtube.com/watch?v=WtV6r9gpObY \\;he appears to have one installed on his Rocker
David
