nope\\; I was going to wire them internal &\\; started to take the tank off, but decided against it now. So I just bolted the tank up &\\; left them external. \\; I didnt have to lengthen the wiring because I went w/ knuckle bars.
I have a 2000 softail deuce. \\; \\;I keep blowing the accessory fuse, \\; Plus the bike won't start now, it turns over just won't start. \\; The only thing that I have done lately is replace the rear tire.
jrobb55, you should start your own thread with your prob.
but off the top of my head check the wires for the rear directionals on inside of fender for pinched wires
What year is the bike?
they had some issues with sharp welds on the oil tank and it cut thru the wiring harness. Mine shorted and had to be towed but was cover under warranty
Mine's an '08. \\; \\; The starter &\\; accessory fuse blow everytime I hit the start switch. \\; Im guessing it would then be in the right switch housing somewhere but dont see anything.
